Hello. I was using VirtualDubMPEG2 to take my MPEG2 files and compress them with the XVID codec. That worked out well, but some of my files were too large. I have this other program called AVS Media Encoder which is pretty much just a built in compressor. I used it on my files to convert them and compress them to .mp4 and it worked out well since the files reduced by another 1/2 size. Now, however, when I try to use VirtualDub again on normal MPEG2 files I have from my Hauppuage PVR 250, this error comes up which never came up before:
An integer division by zero occurred in module 'xvidcore'...
...while compressing frame 1 from 0125ac88 to 0f030048 using codec "XviD MPEG-4 Codec" (VideoSequenceCompressor.cpp:618)...
...while running thread "Processing" (thread.cpp:150).
Also, now in my compression selection, it lists Microsoft MPEG-4 Video Codec V1, V2, and V3 which was not there before. I tried a few more times and I am guessing that the AVS Media Encoder messed something up on my computer. Does anyone have a clue as to what is going on? Thanks!
Results 1 to 1 of 1
Best xvid encoder
By sanosuke in forum Video ConversionReplies: 4Last Post: 6th Oct 2010, 09:20 -
how do i take avs logo off avs video
By tnwolf35 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Sep 2010, 21:08 -
AVS Media "demo" file-conv S/W inserts voice into cvtd music files
By charlessmall18 in forum AudioReplies: 0Last Post: 2nd May 2010, 16:17 -
Config XviD Encoder to control size
By kevin182h in forum Video ConversionReplies: 6Last Post: 27th Feb 2008, 19:02 -
Windows Media Encoder
By culprit in forum Video ConversionReplies: 2Last Post: 30th Oct 2007, 20:46
