I have a Pinnacle Movie Board Plus with a Intel Core 2 Duo 6320 and four gigs of ram, using VirtualDub to capture from my cable box via composite. I can capture just fine uncompressed, MJPEG or Huffy but the quality is sub-par.
Even at best the quality is not near as good as the image on my TV, but when there is movement the quality takes a severe dip as if there is some sort of motion blur going on. It's so that i cannot tell the difference between uncompressed and using MJPEG compression (configured for highest quality).
Is it an issue with my capture card not being up to snuff or is there a setting i'm missing in VDUB?
What you are probably seeing a result of interlacing. TV is interlaced, interlaced footage will look fine on a TV but not on a computer. If you are deinterlacing, it won't look too good on either.
Ensure you are capturing as interlaced and burn to a DVD to play back on a TV for a quality check, don't rely on what you see on your monitor. -
Thanks for the help. Now that you guys mention Interlacing, it does look like that's the problem. Much appreciated.
composite>>don't expect to get anything good with this
MJPEG >don't expect to get anything god with this
my advice of the day*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE
Deinterlacing or Motion Blur possibly?
By spiegel32 in forum EditingReplies: 9Last Post: 5th Sep 2009, 08:13 -
AVCHD - motion blur problem
By Coroner in forum Newbie / General discussionsReplies: 4Last Post: 8th Dec 2008, 16:59 -
motion blur on tv
By ineedhelp007 in forum Newbie / General discussionsReplies: 3Last Post: 18th Dec 2007, 10:49 -
Motion type blur in premiere
By PharmBoy in forum EditingReplies: 0Last Post: 11th Jul 2007, 19:03 -
> Interlaced and motion blur <
By Dark Alpha in forum Newbie / General discussionsReplies: 53Last Post: 12th May 2007, 16:08
