I have a new Sonty laptop which is high spec including a DL DVDRAM/+-RW/+-R burner. I have been burning dvds successfully for ages on my PC, and with DVD+RW on this new machine without problem. However I can't seem to complete a disc using +R media. There is an error that comes up at the end each time telling me there was problems 'finalising' the disc.
Can someone help me understand what is causing this and what to do about it?
many thanks in advance, Darren
thanks, can you tell me how to retrieve the log file? what is the location? thanks in advance.
Found it...can someone help me diagnose? thanks
====== *** Nero-Burning Rom, History File *** ======
D McLean
(deleted)
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/2002 02:03:20
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 02/04/2003 08:13:44
Nero version: 6.0.0.0
Recorder: <MATSHITA DVD-RAM UJ-850S>Version: 1.20 - HA 0 TA 0 - 6.0.0.0
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <MATSHITA DVD-RAM UJ-850S >Version: 1.20 - HA 0 TA 0 - 6.0.0.0
=== Scsi-Device-Map ===
CdRomPeripheral : MATSHITA DVD-RAM UJ-850S atapi Port 0 ID 0 DMA: On
DiskPeripheral : TOSHIBA MK1234GSX atapi Port 1 ID 0 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1022MB (1046636kB)
Free physical memory: 504MB (516688kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
10.3.2007
DVD-Video
10:47:56 #1 Phase 112 File dlgbrnst.cpp, Line 1818
DVD-Video files reallocation started
10:47:57 #2 Phase 114 File dlgbrnst.cpp, Line 1818
DVD-Video files reallocation completed (no file modified)
10:47:57 #3 Text 0 File Isodoc.cpp, Line 5451
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
10:47:57 #4 Phase 111 File dlgbrnst.cpp, Line 1818
DVD-Video files sorted
10:47:57 #5 Text 0 File Reader.cpp, Line 118
Reader running
10:47:57 #6 Text 0 File Writer.cpp, Line 127
Writer MATSHITA DVD-RAM UJ-850S running
10:47:57 #7 ISO9660GEN -11 File geniso.cpp, Line 3814
First writeable address = 0 (0x00000000)
10:47:57 #8 ISO9660GEN -11 File geniso.cpp, Line 3814
10:47:57 #9 Text 0 File Burncd.cpp, Line 3081
Turn on Disc-at-once, using DVD media
10:47:57 #10 Text 0 File DlgWaitCD.cpp, Line 224
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2286127 (508:01.52)
10:47:57 #11 Text 0 File DlgWaitCD.cpp, Line 229
Write in overburning mode: FALSE
10:47:57 #12 Text 0 File DlgWaitCD.cpp, Line 1688
Recorder: MATSHITA DVD-RAM UJ-850S, Media type: DVD+R
Disc Manufacturer ID: INFOME, Media Type ID: R30, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 7
10:47:57 #13 Text 0 File ThreadedTransferInterface.cpp, Line 757
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original CD pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, CD pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [MATSHITA DVD-RAM UJ-850S ]
10:47:57 #14 Text 0 File Burncd.cpp, Line 3318
Recorder and media-info
Burning to MATSHITA DVD-RAM UJ-850S on a DVD+R media
10:47:58 #15 Text 0 File ThreadedTransferInterface.cpp, Line 910
Prepare recorder MATSHITA DVD-RAM UJ-850S for write in cue-sheet-DAO
DAO infos:
MCN:
TOCTYPE: 0x0 Session Closed, CD fixated
Tracks 1 to 1:
TRM_DATA_MODE1, 2048/0x0, ISRC "", FilePos 0 307200 387330048
10:47:58 #16 Phase 24 File dlgbrnst.cpp, Line 1818
Caching of files started
10:47:58 #17 Phase 25 File dlgbrnst.cpp, Line 1818
Caching of files completed
10:47:58 #18 Phase 36 File dlgbrnst.cpp, Line 1818
Burn process started at 4x (5,520 KB/s)
10:47:58 #19 Text 0 File ThreadedTransferInterface.cpp, Line 2104
Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0
10:47:58 #20 Text 0 File Cdrdrv.cpp, Line 7827
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 07 49 4E 46 4F 4D 45 - 00 00 52 33 30 00 38 23 ..INFOME..R30.8#
54 37 13 02 52 6C 02 7C - 5D 15 15 0B 0A 08 08 01 T7..Rl.|].......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
10:47:58 #21 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 14:20,762 (860762ms) -> OK
10:47:58 #22 Text 0 File DVDPlusRW.cpp, Line 513
Start write address at LBA 0
DVD high compatibility mode: Yes
11:03:29 #23 Text 0 File WriterStatus.cpp, Line 112
<MATSHITA DVD-RAM UJ-850S > start writing Lead-Out at LBA 2286128 (22E230h), lenght 0 blocks
11:03:29 #24 Text 0 File ThreadedTransfer.cpp, Line 227
all writers idle, stopping conversion
11:03:32 #25 SCSI -1176 File Cdrdrv.cpp, Line 1151
SCSI Exec, HA 0, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x72
Sense Qual: 0x04
CDB Data: 0x5B 0x01 0x06 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x72 0x04
11:03:32 #26 Text 0 File dlgbrnst.cpp, Line 1678
Set remaining time: 0:00,000 (0ms) -> OK
11:03:32 #27 CDR -1176 File ThreadedTransferInterface.cpp, Line 1594
Session fixation error
11:03:32 #28 TRANSFER -24 File ThreadedTransferInterface.cpp, Line 1594
Could not perform end of Disc-at-once
11:03:32 #29 Text 0 File dlgbrnst.cpp, Line 1678
11:03:32 #30 Text 0 File dlgbrnst.cpp, Line 1678
11:03:32 #31 Phase 38 File dlgbrnst.cpp, Line 1818
Burn process failed at 4x (5,520 KB/s) -
i once got an error like that (error while finalizing disc) but the disc plays perfectly in my standalone
Darren_NZ,
It may not "help you understand what is causing this", but the log shows that when nero sent a "CLOSE TRACK/RZONE/SESSION/BORDER" command to the drive, there was an empty/incomplete RZONE which prompted the atapi error code of 057204, and the aborting of the burn process.
Since you haven't been having problems burning with +RW, the "what to do about it" is almost certainly to use different (better) media. The INFOME R30 media you used is listed at nomorecoasters.com as 3rd class media. This page should help you pick some better media.
If that doesn't solve the problem, post back to this thread, and we'll dig a little deeper. -
Vegasbud - thanks for the helpful reply - I'll be back to the forum if your suggestion doesnt work. cheers
Sony DVD Arch4, audio problem, pls help
By jazu in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2009, 18:14 -
Anyone know how 2 get subs with media player classic in Windows 7 pls? thx
By js2k in forum Newbie / General discussionsReplies: 5Last Post: 10th Oct 2009, 00:55 -
Problem with Samsung DVD-P181 ! Pls help !
By lucianserpescu in forum SubtitleReplies: 1Last Post: 21st Mar 2009, 13:19 -
Finalising unfinalised DVDs
By philheap in forum DVD & Blu-ray RecordersReplies: 3Last Post: 27th Aug 2008, 15:51 -
Problem when encoding...pls help
By Stetsondolly in forum Video ConversionReplies: 11Last Post: 24th Apr 2008, 17:41
