Greetings all. First time poster here. I tried to find the answer to this problem here in this forum with no luck.
I am trying to convert DVDs (multiple VOB's) to one MPEG2 file for use with my Elgato EyeHome ( this is a AppleTV-like device that has been disontinued by the manufactorer, but still serves its purpose well).
I have used MANY combinations or ripping software, muxing & demuxing software, etc. all with similiar results--at least half my owned DVDs result in MPEG files which show small amounts of repeatable video stutter/skipping thoughout the length of the video, while the audio and AV sync remains perfect.
For instance, I began by using MacTheRipper to do the basic de-encrypting, resulting in a VIDEO_TS folder with all the required components. I would then use MPEG Streamclip to demux, convert AC3 to MP2, and then mux to one big MPEG2 file. These two apps provided a very simple solution. I then used MacTheRipper to combine VOBs and/or demux at the same time. I woud then send this file to Stremlclip with SIMILIAR results--that is, stutter remained, but occured at different places in time (all repeatable).
I then spent some $ on commercial software like Xilisoft's DVD Ripper, DVDxDVD etc. and used other freeware and shareware to demux-convert AC3 to MP2-mux. Again, to no avail.
Alex
I don't know why you are getting stutters at different points when you use these different tools. This can happen if your source DVD is damaged, but you seem to be saying that you have at least one method that works consistently, so it seems unlikely that damage is the problem. I am assuming that all of these VOBs have the same data rate, aspect ratio, audio type/bitrate, etc.
I use a different workflow than you do for accomplishing this. You might want to give it a try and see what happens:
If not yet ripped, rip as a single VOB, demux, transocde audio, remux.
If you've already ripped as separate VOBs, then use D-Vision3's VOB joining tool to create a single VOB file. Then demux, transcode, remux.
error message coverting vob to wmv
By DaveE in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 07:50 -
Coverting Video File to DVD without changing Aspect Ratio
By dwpoze in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 04:35 -
VOB into one(!) mpeg2 file
By mitchellgoosen in forum ffmpegX general discussionReplies: 2Last Post: 13th May 2009, 10:19 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 10:33 -
converted vob files play on computer fine..skip when burned to dvd
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2007, 19:26
