I tried putting it into VDub and then extracting the Wav file, which works, but when I try to convert it I can't play the MP3 that I get....
	What audio format and codec was used in the original video? I think there are certain circumstances under which, for example, VirtualDub might save the audio stream as-is, but still label it a wave-format file.
 I usually just use AVI2WAV (haven't tried it against AC3 AVIs, though) to strip the audio stream from an AVI, but I believe you can also try AVIDemux and Goldwave.If cameras add ten pounds, why would people want to eat them?
  BDrip x264 vs DVD-Rip XviD?By therock003 in forum Blu-ray RippingReplies: 5Last Post: 9th May 2009, 15:38
  Rip DVD to Divx/Xvid with AC3 AudioBy dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 04:25
  How to de-interlace a interlaced DVD-RIP in XVID??By okeygrak in forum DVD RippingReplies: 1Last Post: 27th Aug 2007, 09:52
  dvd rip better than original using Xvid?By bmok in forum DVD RippingReplies: 11Last Post: 10th Aug 2007, 00:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
