I recorded a program on my PVR, transferred it to my PC. I now have two .ts files. I am told that one is an audio file and the other a video file. Ive tried burning them on to DVD using Nero but it doesnt work.
Can someone tell me how to do it ie what programs do I use etc or guide me to a link that will help.
Many Thanks
.ts is usually a HD transport stream with both video and audio. try HDTVtoMPEG2 on the files. if they convert to mpeg2 then you need to re-encode the HD to SD mpg. when they are SD mpg you can then use them in an authoring program to make DVD files which you can then burn.
Ok, got it converted to MPEG2 using HDTVtoMPEG2 - many thanks for that. But after transferring from my PVR to PC im not getting any audio (either before or after conversion)??(Yes, volume contol is on).Originally Posted by aedipuss
How do I "re-encode HD to SD mpg" ? Not sure what u are talking about here. Does HD = (PVR) Hard Drive? And SD?
When I get them to SD mpg what 'authorising program' might I use. -
Try having a look at VSO ConvertXToDVD, I use it to convert HDTV TS files to DVD, just select teh first file and it does the rest, and it handles pretty much any other video format to DVD as well
Give it a go, the trial is fully functional for 30 days
Can't make DVD from files (even an image)
By Karstedt in forum Newbie / General discussionsReplies: 2Last Post: 26th Dec 2010, 17:03 -
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
How to make these Avi files fit to Burn
By jkraze in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 21:24 -
divx files how to make a dvd with this
By sumeshkri in forum Authoring (DVD)Replies: 9Last Post: 23rd Sep 2008, 08:04 -
Make a DVD from VOB files
By jmsrickland in forum Newbie / General discussionsReplies: 5Last Post: 6th Aug 2008, 20:30
