    Jun 2007
    Indonesia
    Hi everyone... I'm actually trying to join videos with HJSplit (The creator recommend me to do so, I assume he/she split the videos with it). But my problem is that the file extension/file type of the 2nd part is not ".002" but is .mpg. The 1st and the 3rd part extension is both right= ".001" and ".003". Is there anyway that I can fix this, other than redownload the file? Thank you so much.
    tried rename the file and join?
    Jun 2007
    Indonesia
    yeah i've tried it, but it didn't work. the file name became .mpg.002.mpg huuu, anything else, please?
    Dec 2004
    Triptonia
    Originally Posted by jagabo
    Do yourself a favor: turn off Windows' "Hide extensions of known file types" option. From Explorer select Tools -> Folder Options -> View. The option is in the Advanced Settings section.
  5. Mod Neophyte redwudz's Avatar
    USA
    I assume you have 'hide extensions for known file types' turned off in 'folder options>views'? Otherwise you may not be seeing the extension and you can't change it.
    A freeware program I use for joining files is filemerger: http://home.planet.nl/~doesw008/filemerger.html It works with video and most any binary file.
    If you have a lot of files with dissimilar names, you might try this program, also freeware: http://www.mediachance.com/free/renamer.htm
    Jun 2007
    Indonesia
    Thank you sooo much 45tripp and redwudz for your help Thanks!
