probably a stupid question. i've done much research trying to figure out how to rip dual audio streams from .ogms and when i finally do... the application won't open. am i doing something wrong... are my settings messed up? thanks in advance.![]()
It's a command-line/console application, and doesn't have a GUI. However, you can create a shortcut to it on the Desktop (for example), and drag the OGM files onto the shortcut. It'll demux the streams from the OGM to the same directory.
If cameras add ten pounds, why would people want to eat them? -
i'm an idiot. thank you ;D
another question though, if it has no GUI, how do i modify the settings? -
You have to specify them on the command line. For example, here's the command-line help for OGMDemuxer:
I usually don't bother with the options and let it demux everything, so I haven't experimented with any of the options. But, if you use specific options often enough, you can add them to the shortcut file I mentioned earlier.Syntax : OGMDEM~1.EXE <mode> <file> [options] [[--wav] [--mpeg2-aac] n
utfile] ...
<mode> what to demux:
tracks -> demux tracks
tags -> demux tags
all -> demux both
<file> Ogg/OGM file to process
n
utfile demux track with serial n to outfile
--wav demux to a wav file (non-vorbis audio only)
--mpeg2-aac force as mpeg2-aac (default is mpeg4 for AAC)
Options :
--help show this help
-l/--log <file> log to <file>
--verbose increase the verbosity level
-v[v[...]] increase the verbosity level (by the number of 'v')
-p/--progress show progress
--safe don't process data that appear erroneous like
- oversized Packets
--reconstruct try to reconstruct (pad) missing data (due to corruption)
--track-index replace track serial by track index in demuxed filenames
--legacy-avi do not create OpenDML AVI (unless size>2GB)
--separate-chapters demux chapters in a separate file
--dos-eol <CR><LF> EndOfLine in output text files (except logs)
--output-path <path> out path (default = input), ignored with n
utfile
dvd tray won't stay closed
By toddster385 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 4th Apr 2011, 13:49 -
Canon Hi8 A1 won't stay on
By Sew Sporty in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 3rd Jan 2011, 21:51 -
PC Monitor Won't Stay On
By The Monkees in forum ComputerReplies: 4Last Post: 11th Mar 2008, 00:15 -
Computer keeps shutting down, won't stay on.
By Super Warrior in forum ComputerReplies: 6Last Post: 9th Aug 2007, 16:34 -
XP won't stay with the appearance I pick
By The Fred in forum ComputerReplies: 21Last Post: 13th May 2007, 14:35
