Hi,
For some reason my dvdshrink was not ripping a certain DVD, so I used DVDFab. The thing is that DVDFab didn't use any compression, and now I need to fit 8GB in 4.7GB.
What tool wouuld you suggest that will let me:
1) Compress the existent files to make it fit on DVD+R
or
2) Tool that will let me pick only the main movie to burn to DVD+R, so I can make it fit.
Ideally a tool that would do both things.
I appreciate your help.
Rip to your HDD with, then open in Shrink and re-author or reduce. For big reductions, consider using DVD Rebuilder with HCenc instead of Shrink. The Pro version of Rebuilder will let you re-author. The free version does not.
That said, you cam do a movie only rip with DVD Fab Decrypter if you want, and save yourself some time.Read my blog here.
Re-authoring is a simple as drag and drop. The only thing that takes time is if you have to reduce the size. And if Shrink is taking too long for you, then you won't be happy with anything else. Shrink is about as fast as it gets. This leaves you with two choices. Burn to DL discs so everything fits, or buy a faster computer.
Read my blog here.
guns1inger has you covered.
I back up my almost 8gb Star Trek episodes with Shrink. It takes a little over an hour and a half. I know it's going to take an hour and a half so I go do something else for an hour and a half. No way around it using Shrink for me. And I am satisfied using Shrink w/ deep analysis and AEC set to sharp. Going from 8gb to 4.7gb takes time. But if quality is a factor it's well worth it..
Stick with Shrink.
Regards, NL
DVD file too large to burn to disc..how can I make it fit?
By Natalie88 in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2010, 09:14 -
How to make these Avi files fit to Burn
By jkraze in forum Newbie / General discussionsReplies: 1Last Post: 1st Feb 2010, 21:24 -
Got two .avi files and need to pare them doen to fit on one dvd, help!
By BroCraig in forum ffmpegX general discussionReplies: 8Last Post: 25th Aug 2009, 13:35 -
Need to compress 5 VOB files to fit in one 4.7GB DVD...
By pmolson in forum Video ConversionReplies: 12Last Post: 20th Oct 2008, 18:52 -
Mpeg files wont fit onto one DVD
By jayman34 in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 03:43
