    Mar 2005
    Philippines
    Hi, Please help me coz' am new to these 2 programs in some other forum some are suggesting to use DVDShrink some are DVDRebuilder and in here I've searched for the comments on other users of these tools but am still confused, I just want to fit my 2 movies in 1 DVD, I used DLP to make my DVD and its over 4.7GB. I'm hoping anyone here who has an extensive knowledge between these 2 programs will help me to which am gonna use. Thanks in advance.
    BTW I have ffdshow rev1058+, xilisoft video converter and nero7 premium installed will any of these 2 programs affect my codecs installed?
    Aug 2004
    IMO if it's only a little bit over 4.7GB then you can use DVDShrink. It it's significantly bigger than 4.7GB then DVDRebuilder. Shrink is a transcoder and faster, while Rebuilder is better suited for re-encoding and slower.
    Mar 2005
    Philippines
    Yes it is, its only 5.1GB, can DVDShrink allow me to retain my menu? It's just simple menu to be able to select which one to play. Pinstripes23 is DVDShrink safe? I mean are there any circumstances will affect my codecs installed? Thanks for replying!
    Aug 2004
    yes it can retain menu. yes it's safe.
    Mar 2005
    Philippines
    Pinstripes23 you saved me from a lot of work!! Thank you very much for your help.
