Hello... question may be a bit n00bish.. sorry..
I have a few DVD ISOs that are in PAL format, and I need to burn them off as NTSC. What's the most painless way to accomplish this?
The easiest way is to buy a DVD player that supports PAL such as a Philips or Oppo.
The basic approach is
1. Extract the DVD content from the ISO
2. Extract all the content from the DVD structure - video, audio, menus backgrounds etc.
3. Convert all elements - resize and re-encode video and stills etc to NTSC resolution
4. Apply pulldown from 25 -> 29.97 fps
5. Re-assemble all the elements back into the DVD structure
6. Burn a new discRead my blog here.
Originally Posted by MOVIEGEEK
The easiest way I have found to make ntsc playable copies is to use convertxtodvd.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
.iso NTSC to PAL with subs
By LoveMyslf in forum Video ConversionReplies: 17Last Post: 12th Jun 2008, 11:01 -
Converting PAL ISO to NTSC for DVD-Video
By Nate7410 in forum Authoring (DVD)Replies: 1Last Post: 18th Sep 2007, 14:27
