I'm using Adobe Premiere Pro 2 and I have installed debugmode frameserver into my plugins folder (both common and the en_us folders) and then opened up premiere - however when I go to export - movie - and then go into my output settings, there is no option for debugmode frameserver.
Does anyone know how to get this to work with Premiere Pro 2.0?
If not, is there a free alternate plug-in I can get to frameserve video/audio from Premiere Pro 2.0 ???
Thanks!
A picture is worth a 1000 words:
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
That's exactly where I was looking for "DebugMode FrameServer" however it wasn't there. Any suggestions on how I could get this to work? Should I uninstall it and then reinstall it only in the common plug-in folder?
It's NOT listed on my list of "File Types" when I try to export my movie. -
debugmode frameserver is no longer needed. Why are you using it? Premiere Pro can import and export fine without needing that thing.
I still need DebugMode to export to TMPGenc Express 3.0 from Premiere Pro 2.0
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
It should be installed in the "en_US" folder that's inside the "Plug-ins" folder. If it shows up in the list like my image, then you have it correctly installed. I assume you know how to use it, so I won't go into details...............
lordsmurf - It's not needed for the average user, but it is very useful to the advanced user. I use it all the time when I edit HDV material and much more. I can edit full resolution m2t's and export via Frameserver to multiple formats through the use of Avisynth to process.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
I want to use it so I don't have to export a huge AVI file and then use that AVI when I open up quicktime - I'd like to frameserve it to quicktime since I'm doing some tests.Originally Posted by lordsmurf
Premiere CS5.5 and DebugMode Frameserver - not rendering keyframes?
By ohcomeon in forum EditingReplies: 1Last Post: 14th Jul 2011, 11:52 -
Frameserver for Premiere Pro cs4 64 bit
By helionfilm in forum Video ConversionReplies: 3Last Post: 6th May 2011, 08:13 -
DebugMode frameserver output: RGB24, RGB32 or YUY2 ?
By codemaster in forum EditingReplies: 8Last Post: 6th Jan 2011, 13:09 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 04:22 -
Debugmode Frameserver questions
By vid83 in forum Video ConversionReplies: 5Last Post: 31st Dec 2008, 18:52
