i went to C:\Program Data\DVD Shrink in Windows Vista and under there is all the analyze files from Shrink. it says it's a windows shell type file. Is it safe to delete these? or should i leave them alone? please help.
Delete them. They are only useful if you wanted to shrink the same DVD again and then they will save you some time. Otherwise, they are just taking up space. Note, though that they don't take up much space.
like redwutz says if you have to.... they are harmless data files caching the info to save you time. i have over 800 of them and they take up an entire 7mb combined.
Restoring "Safe To Remove Hardware" Popup Confirmation
By CobraPilot in forum ComputerReplies: 8Last Post: 3rd Jan 2012, 13:35 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 02:27 -
Problem rebooting into Vista after "Safe Mode"
By RKelly in forum ComputerReplies: 1Last Post: 3rd Jan 2008, 23:31 -
DVD larger than 4.7GB, is it safe to use "AutoFit" and burn on 4.
By geek2330 in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 10th Oct 2007, 15:49 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
