Hi folks!
First of all, I'm completely computer illiterate- I'm blonde, so don't tend to know what any of the jargon means!
I'm sure I'm trying to do something very simple, but don't know where to start!
I have a JVC digital camcorder (a GR-D240 EK) with a DV link.
In my blondeness i figured I could send off for a DV link cable, so I bought one which I thought had a USB part on the other end!
It turns out its a 6 pin IEEE 1394 plug meant for a pc equipped with a capture board with that terminal.
I have pushed and squeezed, but there definately isn't any place to attach it!
What should I do?
Do I send it back? Is there a connection I can buy for it?
Would that even work or is there software that I need as well?
Help!
Maz xx
You need a firewire(IEEE 1394) card, about $15. Very easy to install, open the case and plug it in.
You can't use USB no matter what to transfer video from your cam.
To get the video to your computer there's many programs but for free you can use WinDV once you have the card installed. -
As you are in the UK, get yourself one of these http://svp.co.uk/products-solo.php?pid=407&prepg=1
It comes complete with cable so you won't need the one you have bought and software. The last one I got came with a free version of Ulead DVD Moviefactory which will do everything from capturing through to burning to DVD and is fairly straightforward to use.
That will just leave you with the problem of fitting it into your computer.......
Can I connect camera HDMI to camcorder HDMI?
By Darryl In Canada in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2012, 17:06 -
Please help me to connect the camcorder to a long distance
By varunjith1990 in forum Newbie / General discussionsReplies: 16Last Post: 3rd Dec 2011, 22:57 -
Don't seem to be getting anywhere. How to connect pc to dvd recorders
By xtube in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 22:26 -
how to connect an old camcorder to USB capture device
By deanno in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 30th Dec 2009, 14:40 -
WMM recognzes camcorder but DVIO and WinDV don't?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 5th Dec 2007, 05:34
