  1. I used to use VLC on my XP, but then I got vista, I downloaded VLC and all it is is Audio, and only colours as video. Has anyone else had this problem? I need some help.
    Video is usually colors...or do you mean no video? then be sure to use latest vlc and you can also try goooogle, http://www.google.se/search?q=vlc+vista+no+video&ie=utf-8&oe=utf-8&aq=t&rls=org.mozill...ient=firefox-a (several tips).
  3. Go to Settings -> Preferences -> Video -> Output Modules (enable Advanced options), then try the different options for Video Output Module, especially "DirectX video output".
  4. Thanks a bunch! It was really bugging me.
