Got a 512x384 video I want to force Premiere Pro to resize to the 720x480 template in which I've been editing it. I'm sure there's a way, but PPro's help file doesn't make it easy to find. Any takers? ;p
Put the video on the timeline and go to the Sequence window. You should see a 720 x 480 rectangle and your video centered in it. The video should have an outline with handles to let you change the size. Drag each corner into the corresponding 720 x 480 corner. It should snap.
You ideally need to do this before editing so that the scaling will apply to all the new clips once you start cutting etc. If you already have multiple clips, select the entire track and then do the scaling. If that fails, apply the scaling to one clip, copy the clip (Ctrl-C or right click/Copy), select all the clips and Paste Attributes.
I can't access my PPro right now, so the above is from memory. There may be another way, such as reinterpreting the footage, but I'm not sure.
BTW - I agree about the documentation - it's dreadful.John Miller -
Awesome. Will get right to it once I'm back at my pc. Great thanks!
Split video with Premiere Pro
By improvisation in forum Newbie / General discussionsReplies: 4Last Post: 4th May 2010, 16:18 -
automatic video resize in Premiere Pro where there was none before
By turk690 in forum EditingReplies: 4Last Post: 26th Apr 2010, 03:52 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27 -
Getting quality video on youtube with Premiere Pro?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 13th Dec 2007, 19:51 -
Premiere Pro audio/video sync
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 11th Nov 2007, 16:36
