I have a dodgy USB socket on this PC.
I never thought a PC could mess a memory stick up, up until today.
I scanned my memory stick in Easy Recovery to find loads of bad I/O Sectors.
There MUST be a way to fix this.
I have tried CHKDSK, Spinrite, Diskeeper and of course Easy Recovery.
No luck.
What do i do now?
It's crazy.
Many Thanks.
plug it in, right click on it in my computer and format.
But even that doesn't work though.
I still get bad sector errors with easy recovery :S
This is what is bizarre. -
pretty weird. i use them all the time and haven't had any bad luck yet. try re-formatting that one on a different computer and if it still has errors try sending it back as defective, otherwise all you have there is an odd shaped keyfob.
How do I get my PSP videos onto the memory stick?
By Prot in forum Portable VideoReplies: 5Last Post: 23rd Jan 2012, 11:32 -
Test the memory stick
By alintatoc in forum ComputerReplies: 2Last Post: 13th Jun 2011, 13:52 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31 -
USB memory stick recommendation...
By retroborg in forum ComputerReplies: 5Last Post: 12th Sep 2007, 06:55 -
Memory stick?
By bevills1 in forum ComputerReplies: 2Last Post: 4th Jun 2007, 09:10
