Results 1 to 17 of 17
    Jan 2004
    Queens
    ok I'm trying to help a friend of mine out. He has several movies that were given to him that were zipped. Everytime he tries to unzip, it goes to 100%, then he gets CRC error on file r.86. He has defragmnented his pc. Checked for virus/malware, everything clean. It's weird. He has used, winzip, winrar nad now power archiever. Nothing works. It goes all the way to the end, 100%, then CRC error on file r86. Can anyone help please. Thanks.
    Oct 2005
    666th portal
    it's a bad rar. unless you have par files to fix it or it has recovery record built in you are out of luck. try starting winrar, navigate to the folder with the bad rar(file/change drive/open folders) highlight the bad r86 and click repair in the upper right. treat as rar. if it finds recovery record it may be able to fix. otherwise it's time to get a new copy of r86 or delete them all.
    Jan 2004
    Queens
    Thanks for the update, BUT, he has been given these 3 movies 4 times, and 4 times the same problem, but in my pc they unzip with no errors. We are trying to figure out why on his PC and no other,
    Oct 2005
    666th portal
    does he have the same version of winrar. does he have enough space on his hard drive. is his hard drive formatted in fat32. could be a whole bunch of things.
    Jan 2004
    Queens
    Yes same powerarchiever, has enough space on hardrive, formatted fat32, defrgmented no problems. What else. Again its a weird problem. Anything he downloads and unzips, gets the same error.
    Jan 2004
    Queens
    I fixed it. I used chkdsk /f and it fixed the problem. Thank you all for trying to help. Greatly appreciated.
    Jan 2004
    Queens
    Well I was wrong. It unzipped 1 file but not the others. Yet agian, i can unzip them with no problem with my pc, but now his. He did have some errors pop up when i did chkdsk /f but it seemed to fix them. Please help.
  8. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    the file when unzipped may be larger than you can write to a fat32 hard drive. he may need a new one anyway if there are recurring errors. get him a new drive and format it with the ntfs file system.
    Sep 2006
    You will not be able to do anything with that file, it is corrupted.
    moved to another forum, nobody likes me here...
  10. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    I used to use the 'fix' features in Info-Zip's Zip and PKZIPFIX (both command-line), to see if that might help. I don't know if PowerArchiver, WinRAR or others have it, though. (I'm currently using IZArc and 7-Zip; have to check if those have features like that.)
    And yes, make sure you're using the latest version of each unarchiver. It hasn't happened to me with zips, but on rar and some other formats, I've seen errors if the unarchiver wasn't completely up-to-date.
    Jan 2004
    Queens
    Powerarchiever is updated. I told him to buy a new hard drive and reformat it to NTFS. My hard drive is formatted to NTFS, plus his drive might be dying. Thanks all for the responses.
    Jan 2004
    Queens
    Ok I'm back. We cannot get this system to unzip. I give up. Again as previously stated, all 5 movies I can unzip with no problem, but in my friends computer it goes all the way until 100% and the crc error comes up on file r86. I copied file to his c: drive (OS system) and tried there. No luck. He does not want to reform, even though I told him to. I have no more suggestions. Anyone, please.
  13. Disgustipated TooLFooL's Avatar
    Feb 2004
    Opium Den
    are you trying to unzip this file from a hard drive or from a cd/dvd?
    I am just a worthless liar,
    I am just an imbecil
    Jan 2004
    Queens
    from a hard drive. I did chkdsk + scan Disc. Some errors, but fixed. O so I think.
    Feb 2004
    Australia
    Powerarchiever ... no way ... better use zipgenious .
    A: You need the updated unrar.dll to unpack rar files .
    B: NEVER , EVER , try to repair an ORIGINAL ... always create a backup copy before attempting repair ... or else .. opps ... too late then .
    C: Two different pc's can have different results ... we would need the complete specs of both systems to troubleshoot issue , this is , os , service packs , patches , and every program installed on both systems for comparison .
    Some programs can cause system issues , and affect other programs performance / function .
    D: Possible recovery of original .
    Drive rescue may be able to locate the original , just that you must specify the "saved too" format ... same format as hard drive used when file was initially stored on it ... incase drive went through conversion process from fat32 to ntfs .
    Problems can also come from users who do not confirm the data backups regularly that have been stored on cd / dvd .
    E: Your friend needs to get another hard drive soon , rather than later , and use the manufacturers tools to mirror the bad drive to the new drive ... as the chkdsk remains unresolved ... bad to leave in such state .
    Jan 2004
    Queens
    Thanks Bjs. I told him to change his HD. Now the question is which one. His main drive is 80GB and gis 2nd drive is 250GB. Since i copied the files to his nmain drive, still the same error. SO could it be both of them. Also how do you update unrar.dll ? Thanks for the help.
    Jan 2004
    Queens
    Found unrar.dll, thanks. I will try that first. Is Zipgenius better than powerarchiever?
