When I encode with preset mpeg-4 480w, everything works just fine, but when I try to encode with the h264 preset, I can't hear the sound.
Any suggestions?
Results 1 to 18 of 18
nevermind, i did the h264 640W preset, and it said finished in 2 seconds and it didn't work. I used mactheripper like I've seen dozens of people demand that anyone should use using a mac, and then I've tried this program for 5 days now and not once has it worked and I've tried at least a dozen times in a dozen different ways. Even though this program is faster than handbrake, at least handbrake works.
Good! You took a deep breath.
If you open the file in QuickTime player, does it play well? Do a "get info" in QT Player when the file is open and take a screen shot of the dialog. Post it so we know what the source material is. If there's a video file available that we might download so we can test it ourselves, perhaps we might find the cause (and the solution or a workaround).
If you try to encode using ffmpegX, click the little "i" in the encoder window, copy the relevant portions of the command-line garbage that you find there, and paste it into a new posting.
Both of the above should go a long way toward resolving this issue.
I have already made a thread about this issue in which i posted the information that i got when i clicked the i button, but i'll copy/paste it onto here...
Encoding started on Thu Jul 12 10:04:28 EDT 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
configuration: --enable-mp3lame --enable-gpl --disable-vhook --disable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads --enable-x264
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
built on Apr 15 2006 08:41:02, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
x264 [info]: using cpu capabilities Altivec
mp4 [info]: initial delay 0 (scale 24000)
Input #0, mpeg, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/VIDEO_TS/NAPOLEON_DYNAMITE_SE_D1 Title 1.VOB':
Duration: 00:54:47.1, start: 0.203578, bitrate: 15624 kb/s
Stream #0.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
Stream #0.1[0x20]: Subtitle: dvdsub
Stream #0.2[0x21]: Subtitle: dvdsub
Stream #0.3[0x22]: Subtitle: dvdsub
Stream #0.4[0x23]: Subtitle: dvdsub
Stream #0.5[0x24]: Subtitle: dvdsub
Stream #0.6[0x25]: Subtitle: dvdsub
Stream #0.7[0x26]: Subtitle: dvdsub
Stream #0.8[0x27]: Subtitle: dvdsub
Stream #0.9[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #0.10[0x81]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.11[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.12[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #0.13[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Output #0, yuv4mpegpipe, to 'pipe:':
Stream #0.0, 23.98 fps(c): Video: rawvideo, yuv420p, 640x352, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Press [q] to stop encoding
video:0kB audio:0kB global headers:0kB muxing overhead inf%
x264 [info]: slice I:1275 Avg QP:19.24 size: 28172 PSNR Mean Y:44.88 U:47.70 V:48.15 Avg:45.62 Global:45.20
x264 [info]: slice P:135101 Avg QP:22.37 size: 3078 PSNR Mean Y:42.71 U:46.37 V:46.82 Avg:43.53 Global:42.84
x264 [info]: mb I I16..4: 25.5% 0.0% 74.5%
x264 [info]: mb P I16..4: 2.5% 0.0% 2.0% P16..4: 46.1% 0.0% 0.0% 0.0% 0.0% skip:49.4%
x264 [info]: final ratefactor: 20.78
x264 [info]: PSNR Mean Y:42.725 U:46.378 V:46.835 Avg:43.553 Global:42.856 kb/s:635.30
encoded 136376 frames, 5.19 fps, 636.32 kb/s
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/VIDEO_TS/NAPOLEON_DYNAMITE_SE_D1 Title 1.VOB.ff.video.mp4':
Duration: 01:34:48.0, start: 0.000000, bitrate: 637 kb/s
Stream #0.0(und), 23.98 fps(r): Video: h264, yuv420p, 640x352
Input #1, mpeg, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/VIDEO_TS/NAPOLEON_DYNAMITE_SE_D1 Title 1.VOB':
Stream #1.0[0x1e0], 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
Stream #1.1[0x20]: Subtitle: dvdsub
Stream #1.2[0x21]: Subtitle: dvdsub
Stream #1.3[0x22]: Subtitle: dvdsub
Stream #1.4[0x23]: Subtitle: dvdsub
Stream #1.5[0x24]: Subtitle: dvdsub
Stream #1.6[0x25]: Subtitle: dvdsub
Stream #1.7[0x26]: Subtitle: dvdsub
Stream #1.8[0x27]: Subtitle: dvdsub
Stream #1.9[0x80]: Audio: ac3, 48000 Hz, 5:1, 448 kb/s
Stream #1.10[0x81]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.11[0x82]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.12[0x83]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Stream #1.13[0x84]: Audio: ac3, 48000 Hz, stereo, 192 kb/s
Codec type mismatch for mapping #1.1 -> #0.0
It is trying to map a subtitle stream to audio, which of course won't work.Originally Posted by jdfrosty
Try changing the audio track number in the Audio tab.
Or try ripping your source as a file with one video stream, one audio stream and no other streams. Then it should have no problem finding the audio.
Ahh! Case to the rescue.
If you have QuickTime Pro, you might try opening the source in QT Player, doing a "Command-J" and deleting the streams you no longer need. Save the resulting file as a QT "reference" movie (so you won't need a lengthy "save" process). Then try converting again.
OK, I use mactheripper to rip my dvd, how would I be able to set it up with one video and one audio stream using mactheripper? or would you guys recommend another program for mac ripping?
and I had already tried changing the audio track from 0 to 1, should i still try others? and should i "add audio" ?
well guys, i appreciate the help, but i ripped the dvd again selecting only one audio and only one video stream, and it came in two files. One was a .ac3 file (i assumed this to be audio file) and one was a .m2v file (i assumed this to be video file). Neither of these would play on quicktime. Then I used ffmpegx to encode these files using H.264x264. The file i used in the summary tab was the .m2v file and i clicked the "add audio" button in the audio tab and added the .ac3 file and changed the track number from 0 to 1. And instead of giving me two files (one was a video.mp4 and a audio.mp4) it gave me one video.mp4 file. And like before, the video.mp4 file plays perfectly, but only sound.
this is the process info[u]
Encoding started on Sun Jul 15 11:44:55 EDT 2007
Input #0, mpegvideo, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/NAPOLEON_DYNAMITE_SE_D1 Title 1.m2v':
Duration: 01:14:14.3, start: 0.000000, bitrate: 9799 kb/s
Stream #0.0, 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg2video @ 0x45a630]end mismatch left=-1
[mpeg2video @ 0x45a630]Warning MVs not available
[mpeg2video @ 0x45a630]concealing 45 DC, 45 AC, 45 MV errors
[mpeg2video @ 0x45a630]ac-tex damaged at 44 29
[mpeg2video @ 0x45a630]invalid mb type in B Frame at 44 29
[mpeg2video @ 0x45a630]00 motion_type at 44 29
[mpeg2video @ 0x45a630]concealing 1 DC, 1 AC, 1 MV errors
and here is the rest...
x264 [info]: slice I:1299 Avg QP:15.95 size: 40101 PSNR Mean Y:47.05 U:48.98 V:49.38 Avg:47.60 Global:47.26
x264 [info]: slice P:129531 Avg QP:19.04 size: 6012 PSNR Mean Y:44.53 U:47.49 V:47.94 Avg:45.24 Global:44.68
x264 [info]: mb I I16..4: 17.7% 0.0% 82.3%
x264 [info]: mb P I16..4: 4.6% 0.0% 2.8% P16..4: 65.7% 0.0% 0.0% 0.0% 0.0% skip:26.9%
x264 [info]: final ratefactor: 17.47
x264 [info]: PSNR Mean Y:44.552 U:47.506 V:47.952 Avg:45.260 Global:44.701 kb/s:1218.00
encoded 130830 frames, 3.78 fps, 1219.02 kb/s
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/NAPOLEON_DYNAMITE_SE_D1 Title 1.m2v.ff.video.mp4':
Duration: 01:30:56.7, start: 0.000000, bitrate: 1219 kb/s
Input #1, mpegvideo, from '/Users/Desktop/NAPOLEON_DYNAMITE_SE_D1 Title 1/NAPOLEON_DYNAMITE_SE_D1 Title 1.m2v':
Duration: 01:14:14.3, start: 0.000000, bitrate: 9800 kb/s
Stream #1.0, 29.97 fps(r): Video: mpeg2video, yuv420p, 720x480, 9800 kb/s
No audio or video streams available
MKV [h264/aac] to mp4 conversion problems...
By DestructoEH in forum Video ConversionReplies: 6Last Post: 12th May 2009, 20:19 -
Mov h264 to MP4/h264 Conversion
By Scooter_NJ in forum Video ConversionReplies: 2Last Post: 26th Mar 2009, 11:07 -
[SUPER] iPod on TV conversion problems (heavier and lots of squares)
By Horrigan in forum Video ConversionReplies: 9Last Post: 25th Mar 2009, 00:02 -
HD WMV w/5.1 Sound Conversion to iPod Format Problem -- Help Please!
By VixenofVenus in forum Video ConversionReplies: 10Last Post: 2nd Oct 2008, 13:59 -
AVI conversion to H264 for iPod not quite working
By rumplestiltskin in forum MacReplies: 11Last Post: 1st Dec 2007, 01:48
