I am very new to the life of VCD's and I need a few minutes of someone’s time. I recently bought an ATI TV Wonder card and I have installed it along with the accompanying software.
My question is this... I can watch TV on my PC so I record a clip and save it as whatever.mp2... Now what do I need to do to watch what I recorded? When I just try to launch it I get nothing!.!.!
I am going to be on AIM all night so please AIM me or email me if you can help.
AIM - seancanes
Hotmail - sean_delaney@hotmail.com
Sincerely,
Sean Delaney![]()
What you need to do is figure out what compression codec that you're using. If it's an MPEG 1/2 codec ( which it's probably not) then you should be able to play it in Windows Media Player. If It's Mpeg-2 then you might need to download the MPEG-2 Codec located on this site in the tools section. If it's not MPEG then it's avi and you should save it as Whatever.avi and then you can play it in Windows Media Player. You should only use the .mp2 file extention for mpeg sound files. Try changing the Filename to Whatever.avi and then double-click on it. It should play.
Hope this helps!... -
Thanks so much for your help... After downloading the Codec I was able to watch what I recorded....
Now I just need to figure out the best way to compress these little clips so I can post them on the internet.
Can anyone point me to a tool to do that?
Sincerely,
Sean Delaney
Congratulation to MCanes...
I am also a very new person to VCD recording who desperately need guidance. Can you describe the systems specification you had?
I recently purchase the Pinnacle Studio VCD card to capture video clips into *.mpg format from a VCR. However, I faced many problems like audio and video not in sync. I don't know what is the problem... can anyone out there please help.
My system specification is:
HP Pavilion 9710 Pentium 3 866Mhz
320Mb RAM
Direct AGP video graphics
11MB UMA video memory
Thanks a lot in advance.
VCD to VCD back-up
By fiiido in forum Authoring (VCD/SVCD)Replies: 4Last Post: 29th May 2011, 12:39 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
