I recently made a VCD using the guides, but set the resolution at 320 x 368, I cropped it and its final resolution came to 320 x 304, it all works fine and all on my PC - I have no standalone DVD player to check if they actually do work on a DVD Player (that can play VCD's) so I gave it to a friend and he said its all messed up... is this because of the resolution setting? or is his DVD player unl33t?
Yes, it is because of your framesize.
You should use just the standard one (352x240/288 ).
Read "What Is VCD" on the left hand menu.
Regards.Michael Tam
w: Morsels of Evidence -
Make sure you stick to the actual specs of VCD (they are listed on this site)
Pal 352-288, 25 images/sec
NTSC 352-240, 29.97 images/sec
Both have audio 224 kbit/sec
Finally, you need to use a software that can burn VCDs, like Easy CD Creator Deluxe, WinonCD or Nero to name a few.
Finally, you need a DVD player that can read CDRs.
Cheers
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 08:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 07:36 -
What's the best format and resolution for LCD TV or HDTV from DVD and VCD.
By newbievideohelp in forum Video ConversionReplies: 6Last Post: 6th Nov 2009, 14:23 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 13:16 -
viewing a QVGA/VGA resolution video with NTSC DV resolution (with a TV)
By Lightbreaker in forum EditingReplies: 1Last Post: 6th Jan 2009, 02:57
