I have a big problem. I am capturing the video from my camera and the audio is skipping. The only thing i can conclude is that i used an old tape. Any suggestions
If the problem can be rectified what can be done
How's My English?
firewire from cam to computer? if not that could be the problem. or maybe your comp is too old/slow?
are the specs in your profile correct? With 256 megs ram and 25 gb hard drive under XP and doing video capture, it will be difficult. Consider adding at least a 250 Gb SATA hard drive and getting at least 512 mb total of ram, 1 Gb would be ideal.
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Skipping audio problem!
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Mar 2011, 12:02 -
WD TV USB Player 5.1 Audio Skipping
By njsges in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Jan 2009, 03:31 -
Skipping in beginning of WinDV capture
By rjack in forum Capturing and VCRReplies: 1Last Post: 10th Jan 2009, 23:16 -
Matroska Video - Audio delay when skipping
By strutter_uk in forum Newbie / General discussionsReplies: 2Last Post: 15th Jan 2008, 12:08 -
dazzle video capture frame skipping
By VistaXP in forum Capturing and VCRReplies: 2Last Post: 2nd Jun 2007, 19:00
