CCE produces a HASP Protection error...(HASP not found (-3) ), when I try to start it, this only happens on my computer with which I have Vista installed. I use DVD Rebuilder Pro Ver. 1.10.7 and CCE SP Ver. 2.70.2.12.
Would appreciate any feedback.
Cormor
Results 1 to 9 of 9
Originally Posted by cormor
8) -
Did you try installing and running it in 'Administrative' mode?
Moving you to Newbie General forum.
And welcome to our forums. -
For info, in response to my original post Cinema Craft Encoder version SP2 is Windows Vista compatible.
Has DVD Rebuilder become compatible with Vista?
I had to back up to XP from Vista to run DVDRB.;/ l ,[____], Its a Jeep thing,
l---L---o||||||o- you wouldn't understand.
(.)_) (.)_)-----)_) "Only In A Jeep" -
AFAIK, DVD Rebuilder works with Vista. I have it installed in Vista, but haven't ran the program all the way through. The DVD Rebuilder Pro 1.20.5 version is listed as compatible in: http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List and the regular version should be the same.
Funny - they were discussing problems with DVDRB Pro in the DVD Rebuilder forums not a month or so back. Anyway, it seems my newer Dell runs better on XP Pro....
Well, DVDRB has a lot of separate programs to run and it wouldn't surprise me for one of them to have problems with Vista.
I ran it for about ten minutes as a test and it seemed OK, but I haven't had the time to run a DVD all the way through. Most install problems with Vista are helped by running as a Administrator. I have found very few incompatible video programs using Vista. Most of them were poorly written or used older software.
Yes, the version of DVD Rebuilder pro I am using Ver. 1.10.7 is compatible with CCE Ver SP, and both are working just fine with Vista. I have run through the programs fully and have successfully backed up a couple movies.
Cheers...Cormor
Cinema Craft Encoder Sp 2.67.00.27
By Gwar in forum Video ConversionReplies: 1Last Post: 19th Feb 2012, 11:32 -
Problem with Cinema Craft Encoder SP and Windows 7
By echo1434 in forum Video ConversionReplies: 6Last Post: 24th Dec 2011, 16:51 -
Cinema Craft Encoder Issues converting to 16:9 etc.
By lapetite_66 in forum Newbie / General discussionsReplies: 11Last Post: 8th Mar 2010, 20:09 -
Help with Cinema Craft Encoder
By Topcat360 in forum Video ConversionReplies: 31Last Post: 29th Jan 2008, 16:51 -
Cinema Craft Encoder Plugin
By MI6 in forum Video ConversionReplies: 1Last Post: 11th Aug 2007, 18:05
