i learned from this forum that the reason i'm getting audio dropouts when i use mpeg streamclip to demux discs burned on my hdd/dvd recorder is because panasonic use a faulty aac encoder. i'm not able to remedy this problem because there's no software available for mac users that can fix the dropouts. (as far as i know.)
so i'm thinking of getting a new machine to replace my panasonic dmr ex85. i would like at least a 160GB drive, and the ability to burn both PAL and NTSC discs (but not necessarily convert between standards). i am really keen on the quality of dvd encoding.
i would really appreciate any recommendations that board members might have ...
thanks,
mark
	You might want to take a look at this thread:
 https://forum.videohelp.com/topic332696.html
 I'm not sure exactly which models might be available in the UK, or what they cost, but the list of models available in Canada, Europe, and Asia is encouraging, and I know this has been one of the best product lines.When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
	thanks - i had already looked at that thread.
 is pioneer generally a more reliable manufacturer ?
 does anyone have experience of using a pioneer dvd recorder and demuxing on a mac in the way i have described ?
 any advice much appreciated.
 mark
	I am not familiar with mac's but on a pc that error happens with that software with every brand of recorder tested.
 https://www.videohelp.com/forum/archive/panasonic-dvd-recorder-amp-timecode-breaks-audi...s-t329862.html
	so does a timecode break always mean there will ultimately be a sound dropout ?
 i have used mpeg streamclip to demux vob's that i have downloaded or been sent, and not noticed any problems.
 mark
	I did not test further since the software was already indicating errors that no other software I own showed. I have tested and used the Panasonic ES10, ES30V, ES35V, ES37VK, EH55 and have never seen any audio drop out. I have also tested LG's, Pioneers, JVC's and never experienced any drop outs with those either yet they all show a time code error with this software.
 Have you done this test with a recording from any other brand of dvd recorder with this software ( not downloaded ) or do you experience dropouts before you attempt to use this software?
 [edit]I did test this software with some video that did not come from a recorder and it did not show the time code error. The error only occurred with video from recorders.
	at the moment, i am finding that panasonic dmr-rx85 discs demuxed with mac the ripper seem to be fine and do not have the dropouts i was hearing before.
 mark
	I have had a Pioneer DVR-5100 since they came out in the UK about 4 years ago. All was great for about two years then the laser became increasingly picky about the disks it either played from or recorded to. I can't use -RW any more and only use TDK -R. But I hardly use it now that I have Sky+.Originally Posted by webstar
 Ripping is easy and the files are accepted by most software.Regards,
 Rob
  Connecting Panasonic DVD Recorders with DV input to PCBy PeBo in forum DVD & Blu-ray RecordersReplies: 30Last Post: 26th Apr 2010, 06:51
  I need to replace Nero recommendations?By Chala in forum DVD RippingReplies: 12Last Post: 8th Mar 2010, 20:49
  HDV player/recorders, recommendations?By acej in forum Newbie / General discussionsReplies: 4Last Post: 3rd Dec 2009, 02:43
  Question on new Panasonic dvd recordersBy heman28 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 20th Feb 2008, 12:37
  Pioneer and Panasonic DVD Recorders w/HD?By MCnDaHouse in forum DVD & Blu-ray RecordersReplies: 15Last Post: 16th Dec 2007, 02:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
