Hi All
Having downloaded Movies (legally ) in avi i have no trouble converting them to DVD but for some that come as a Video Clip (800mb avi ) i don't seem to be able to open them up. Can someone inform me how to do it or point me in the direction of a programme that will do it.
Many Thanks.![]()
Convertxtodvd, Super, etc.
AVI to DVD guides:
https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=AVI+...or+List+Guides
Use GSpot to determine what codec was used in your AVI. Then download and install that codec. -
Thanks Jagabo,
Maybe I,m not explaining it correctly as i use ConvertXtoDvd normally when the file comes as avi and i have no problem.Its when it comes in the form of a Video Clip that CovertXToDVD won't open it that is causing the problem.The Video Clip file says its 800MB avi but i can't open it (I have another two files the same) even tried MagicISO but still no joy. -
Hi Manono,
Done as asked,does this make any sence:-
CODEC = XVID 1.1.2 Final
Container:-
Note - 693MB uneeded bytes at end of file
DIVX Style "packed bitstream" AVI
AVI v 1.0 (0.01%)
Video 92.9 end
AVI OVERHEAD 693MB(99.99%)
To me it means nothing that helps. -
Install the Xvid codec or the Divx codec.
AVI is a "container". It was designed to contain audio and video compressed (or not) with an infinite variety of compression schemes. To decompress a video compressed with a particular type of compression you need the appropriate decompression program (codec = COmpress DECompress).
trying to email MOD video clip, too big. How do I convert??
By Crunchberry in forum Video ConversionReplies: 8Last Post: 22nd Mar 2012, 23:55 -
Adding 'copyright' info to video clip in Ulead DVD Moviefactory 6
By colinb1 in forum EditingReplies: 3Last Post: 19th Apr 2011, 08:13 -
How do I get info about a video clip??
By lugnut430 in forum Video Streaming DownloadingReplies: 4Last Post: 3rd Jan 2011, 20:06 -
you see a clip on YouTube..it looks pristine! So crisp! How to see info?
By coady2000 in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 00:30 -
Can't find a good program to convert .mov/.mp4/H.264/AVC watever video clip
By Nintendo Fan in forum Video ConversionReplies: 8Last Post: 21st Jan 2009, 19:28
