Since I upgraded to WinXP and MovieStar 4.24, captures just stop randomly. I have had failures as little as 5 mins into the capture and gone as long as 1 hour and 52 mins. Some captures go just fine. It only seems to happen with the SVCD template. I have not modified any of the parameters for that template. The time counter stops and the preview stops at the point of failure, but MovieStar still thinks it is still recording. If I hit stop recording, the resulting clip will playback up the the freeze point but has no sound. I only use VCD and SVCD so I don't know if anything else fails.
Is it just me, or has anyone else seen this? Any ideas or solution is greatly appreciated
Results 1 to 1 of 1
My mouse stops working randomly
By sohaibrazzaq in forum ComputerReplies: 2Last Post: 17th Mar 2012, 18:30 -
Ripped video stops randomly for 1 or 2 seconds
By panning in forum ffmpegX general discussionReplies: 2Last Post: 29th Oct 2011, 06:17 -
Recommendation of Video Capture Software for WinXP
By opey in forum Capturing and VCRReplies: 3Last Post: 4th May 2010, 03:16 -
Video Capture with Mplayer, Mencoder or ffmpeg under Winxp. Is it possible?
By gll99 in forum Capturing and VCRReplies: 0Last Post: 11th Sep 2008, 19:00 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 13:03
