    Feb 2006
    Hello,
    I have a large video file about 4 gigs and I need to split into 700 MB files. What is the best (personal recommended) software to use?
    USA
    What format of video?
    Feb 2006
    .avi and sometimes .mpeg
  4. Mod Neophyte redwudz's Avatar
    USA
    With AVI, VirtualDub works very well for me. Use 'Direct stream copy'. With VD, I use the 'Key' icon to move to the nearest keyframe and do the split there. The newest versions can split about anywhere, then only re-encode the affected frames. Some codecs, Xvid for example, only have keyframes ever 300 frames by default. That's one reason it's a poor choice for editing. Watch out for MP3 VBR audio also when splitting as it can cause sync problems, especially when converting from AVI type formats to MPEG.
    With MPEG, I use MPEG-VCR, but with either format, there are other alternatives.
