my encoding keeps failing.
Encoding started on Tue Jul 10 06:52:46 PDT 2007
MEncoder dev-CVS-051126-18:35-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x7c9d3b53
Cannot find codec 'dts' in libavcodec...
[mkv] Track ID 1: video (V_MS/VFW/FOURCC), -vid 0
[mkv] Track ID 2: audio (A_DTS), -aid 0, -alang jpn
[mkv] Track ID 3: audio (A_VORBIS), -aid 1, -alang eng
[mkv] Track ID 4: subtitles (S_TEXT/ASS), -sid 0, -slang eng
[mkv] Will play video track 1
[mkv] Will play audio track 2
[mkv] Will display subtitle track 4
Matroska file format detected.
VIDEO: [H264] 704x396 12bpp 23.976 fps 0.0 kbps ( 0.0 kbyte/s)
[V] filefmt:31 fourcc:0x34363248 size:704x396 fps:23.98 ftime:=0.0417
ADecoder init failed
No accelerated IMDCT transform found
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
Opening audio decoder: [hwac3] AC3/DTS pass-through S/PDIF
hwac3: switched to DTS, 768000 bps, 48000 Hz
AUDIO: 48000 Hz, 2 ch, ac3, 768.0 kbit/50.00% (ratio: 96000->192000)
Selected audio codec: [hwdts] afm: hwac3 (DTS through S/PDIF)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale w=704 h=396]
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Forcing output fourcc to 58564944 [XVID]
Building audio filter chain for 48000Hz/2ch/ac3 -> 48000Hz/0ch/s8...
Building audio filter chain for 48000Hz/2ch/ac3 -> 48000Hz/2ch/s16be...
[format] Sample format big-endian AC3 not yet supported
Exiting...
[libaf] Reinitialization did not work, audio filter 'format' returned error code -2
Couldn't find matching filter/ao format!
Any advice?
It seems that your file is using DTS for the main (Japanese) audio track. DTS is not supported by ffmpegX (ffmpeg/mplayer versions included with the app are waay too old). As far as ffmpegX is concerned, there is nothing that can be done. You can try Handbrake (v. 0.9.3 if you want to export as an .avi file).
Jean-Philippe Schuck
Un générique, un autre jour, le blog sur les génériques de dessins animés
I am not replying to the OP who started this thread in July 2007, but for anyone reading this thread, you may want to see if my help file that I posted yesterday will be of some assistance:
https://forum.videohelp.com/threads/317737-Converting-MKV-to-AVI-using-ffmpegX
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 11:29 -
MKV conversion troubles
By Alexstarfire in forum Video ConversionReplies: 3Last Post: 7th Mar 2010, 15:10 -
troubles converting BD to MKV w/ RipBot264
By runLoganrun in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2008, 06:20 -
troubles with MKV/OGM to MP4
By ironmaidens in forum Video ConversionReplies: 6Last Post: 23rd Aug 2008, 14:18
