Animation Shop gives you the option to export video frames to Paint Shop Pro 7. But the trial download expired. So I deleted them both and bought Paint Shop Pro 8 which came with it's Animation Shop. But the bar that says 'Export To Paint Shop Pro' won't highlight, and it won't let me click it. What do I do now?
Anyone else have this problem?
It might have to do with the fact you deleted version instead of uninstalling it. PSP puts a lot of stuff into the registry, so version 8 may be getting wrong information when it looks at the registry.
(If you did uninstall it and not delete it, the rest of this post won't help - sorry.)
You could try to remove the entries manually via regedit but that's a huge pain and, given the amount of stuff PSP puts in there, you'll likely not get everything.
The best solution is to uninstall version 8, reinstall version 7, open PSP and Animation Shop once (in case some additional stuff happens when you first run them), then uninstall them via Add/Remove Programs from Control Panel. The idea is that this will put in all the right stuff for version 7 and remove it all. Most likely you will get a "trial has expired" message when you run them but it shouldn't matter.
Then install version 8.
No promises but it's what I would do....John Miller
What do you shop online for?
By johns0 in forum PollsReplies: 15Last Post: 19th May 2010, 16:19 -
Computer Repair Shop Software
By Poppa_Meth in forum ComputerReplies: 5Last Post: 19th Jan 2010, 05:52 -
What Is Up With SVP Blank Disc Shop?
By hech54 in forum MediaReplies: 2Last Post: 9th Jul 2009, 00:22 -
Paint Shop Pro - "Sin City" effect?
By stantheman1976 in forum ComputerReplies: 5Last Post: 30th Apr 2009, 15:56 -
FREE Download of Corel Paint Shop Pro X Software
By MJA in forum Off topicReplies: 0Last Post: 13th Apr 2009, 19:55
