Well i have DVD image for some movie *.img, i burned it, i can see 2 audio tracks , the 1st is the movie the 2nd is supposed to be the commentary but i can't hear it, so i download the commentary from the internet and i wanna add it to this DVD without changing the menus or anything else ,
how can i do that,
I have DVD Architect 4.0, but i can't figure out how to do it?
what can i do?
You can't do it with DVD Architect. You will have to first extract the DVD from the .img file, so you get a video_ts folder and associated files, then look at something like IFOEdit or PGCEdit to replace the audio track. You will also possibly have to re-encode the audio to DVD compliance, depending on what it is currently encoded as.
Read my blog here.
The following guide is for adding or replacing subtitles in a DVD without changing the menus:
https://forum.videohelp.com/topic275603.html
You could follow the steps here and replace the commentary instead of replacing the subtitles.
How can I add an audio commentary to a dvd?
By artyjeffrey in forum Authoring (DVD)Replies: 1Last Post: 28th Nov 2009, 03:44 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 11:57 -
Commentary track
By AlanHK in forum AudioReplies: 10Last Post: 6th Nov 2008, 02:47 -
How to remove commentary track in AVI.NET?
By sads in forum DVD RippingReplies: 0Last Post: 23rd Oct 2008, 10:47 -
how to add commentary over dvd audio?
By Denvers Dawgs in forum AudioReplies: 3Last Post: 23rd Nov 2007, 23:58
