Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
    Apr 2007
    Philippines
    i have this software TMPGEnc DVD Author 3 with DivX Authoring, i used the Divx Authoring, now i saw this option that it would make my movie file to 700mb. Now its file format is .divx. after that i could now burn it on a cd-r [because 700 mb will now fit in there]
    but my question Does it gonna play on DVD players even in Simple VCD player?
    *i never tried this before
    try and try
    Feb 2007
    Ireland
    It will if your player supports DivX playback.
    Dec 2004
    Australia
    Well as long as it is DivX certified then it will play, just without extra features (menus, chapter and tags). Even if a player isn't certified, it may still play, just depends if the player recognises the extension or not. Talking MPEG-4/avi compatible players that aren't DivX certified here, not just any player.
  4. If I understood your question it will not play in DVD only players. It will as was mentioned above most likely play if you have a divx/dvd player.
    Tell us the make and model of your player(s) and we could be more help.
  5. Ohhh ho hum I take it this is a film regarding the funeral service of someone? 8)
    Burn the file to a cd-rw and see if your player plays it
    If not burn it to a DVD-rw and check
    If not change the filename from "DH4.divx" to "DH4.avi" and check again
    The electronic components of the power part adopted a lot of Rubycons.
