During the installation of older files on my new computer, I came across a cheatsheet I use to copy/paste chapter-break timestamps into DVDauthorGUI. When I'm recording from a non-chaptered source (TV, VCR), I like to set chapter-breaks 5 minutes apart when I burn the result file to DVD. And here's the cheatsheet I copy/paste from:
00:05:00.00
00:10:00.00
00:15:00.00
00:20:00.00
00:25:00.00
00:30:00.00
00:35:00.00
00:40:00.00
00:45:00.00
00:50:00.00
00:55:00.00
01:00:00.00
01:05:00.00
01:10:00.00
01:15:00.00
01:20:00.00
01:25:00.00
01:30:00.00
01:35:00.00
01:40:00.00
01:45:00.00
01:50:00.00
01:55:00.00
02:00:00.00
02:05:00.00
02:10:00.00
02:15:00.00
02:20:00.00
02:25:00.00
02:30:00.00
02:35:00.00
02:40:00.00
02:45:00.00
02:50:00.00
02:55:00.00
03:00:00.00
03:05:00.00
03:10:00.00
03:15:00.00
03:20:00.00
03:25:00.00
03:30:00.00
03:35:00.00
03:40:00.00
03:45:00.00
03:50:00.00
03:55:00.00
04:00:00.00
04:05:00.00
04:10:00.00
04:15:00.00
04:20:00.00
04:25:00.00
04:30:00.00
04:35:00.00
04:40:00.00
04:45:00.00
04:50:00.00
04:55:00.00
05:00:00.00
It eliminates the klutz factor of trying to type these values in each time.
Results 1 to 9 of 9
I can't remember when it was added. It has been at least a year or so, I believe.
Simply use the visual chapter editor, and use the 'auto add' feature near the bottom of the form. You can assign by various durations of time (such as every 5 min, every 10 min, etc). -
I know you can do it in version 1.010c -- that's when I started using the program, and noticed you can add the chapters every "x" minutes (5-min seems to be the lowest increment).
Regards,
George -
i believe I made the field editable, so any duration (in minutes) can be used. Just type it into that field.
Thanks. That's what I get for missing staff meetings (grin). My last version was the old .099 (???) version ... and on films where I try to add meaningful chapter breaks, I try not to trust Windows Media Player's method (as the program suggests). So, I never used (or saw) the auto-add feature when I upgraded to 1.013. Again, thanks.
I ran into a problem were my 6 minute break ended right on the money and there were no frames for a NEW segment
so now I always check the start time of the last segment and make sure my chapter times leave a few minutes for the last segement so the movie ends , before the end of the last segement
i vary the time 5 - 6- 0r 7 minutes segements
depending on the movie
'Play All' button in DVDauthorGUI works except for '>>|' (next chapter).
By dphirschler in forum Authoring (DVD)Replies: 14Last Post: 14th Jun 2011, 13:49 -
create chapter breaks that return to menu afterwards using PGCedit ?
By spiritgumm in forum Authoring (DVD)Replies: 7Last Post: 8th Feb 2009, 10:07 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
WinTV2000 video bitrate cheatsheet
By AlecWest in forum Capturing and VCRReplies: 0Last Post: 9th Jul 2007, 18:50 -
Want to add chapter breaks to a video. Suggestions please.
By Super Warrior in forum EditingReplies: 3Last Post: 27th May 2007, 14:56
