I have real problems getting ffmpegx to honour the resolution I want. It just seems to output whatever it wants. Despite the fact 352x288 is a valid resolution, ffmpegx outputs 320x240 using mpeg2enc
You can't trust the Finder information on resolution for MPEG-1 and MPEG-2 files, as that comes through QuickTime. And QuickTime re-calculates the resolution from the file to another number that matches how QuickTime Player would display the file.
I'm sure someone on the QT dev team thought it was smart, but it isn't, as 'resolution' is not the same as 'default display size', while they present it as such. (It has to do with displaying 352x288 in a 4:3 window, in effect squeezing and/or stretching the video to fit.)
If you drop your output file back onto ffmpegX, you'll see that it recognizes the true resolution in the Source Format section. The same goes for any other app that reads the resolution of MPEG files, besides QuickTime.
Do you enter online contests?
By johns0 in forum PollsReplies: 5Last Post: 28th Mar 2011, 17:48 -
When and how did the four digit file extension enter the MS world?
By yoda313 in forum ComputerReplies: 4Last Post: 21st May 2010, 00:07 -
Unable to enter registered members area
By Joey9 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 19th May 2010, 12:20 -
interpretation, I try to copy it because I enter the translation again
By krrish in forum Authoring (DVD)Replies: 3Last Post: 9th Sep 2008, 15:14 -
DV-400 : After upgrading FW, holding ENTER does not make DVD regionfree
By ricardonovo in forum DVD & Blu-ray PlayersReplies: 0Last Post: 26th Mar 2008, 16:33
