OK, not exactly. But this is what I'm doing.
I have thousands of images of my daughter in jpg format all with EXIF data intact.
I'm using Vegas 7 (and DVD Architect 4) and dropping all these jpegs onto the timeline (1/2 second a piece) in chronological order. This project will be rendered to DV-AVI for storage on mini-DV and also to mpg for burning onto a DVD for viewing.
I can sort the images into the correct order with no problem.
What I would like to do, in a perfect world, is to extract the date and time from each picture and overlay it, in an unobtrusive manner, onto the image.
Now, I don't know too much about the detailed capabilities of Vegas / DVD Architect. What I do know is that neither manual mentions EXIF data in any way.
Does anyone know how I could do this?
Not sure if there is any utility that will do that specifically in video enviroment but you can do it beforehand in batch mode with Exifer or Irfanview. Irfanview is probably the better choice because it's also does many other things, you can for example crop the images in batches to get the right aspect.
Thanks coalman, I've just given irfanview a try and it works pretty well. I would like some more control / options regarding the font, color, transparency etc so I'll have a look at Exifer too.
Shame there seems to be nothing for photoshop. I've already resized these jpgs with a photoshop droplet and it would be nice to process just once. However, if I'm stuck with irfanview then it seems easy and fast enough. Just would like more flexibility. -
Exifer also goes part way towards what I'm looking to do. It also has the added advantage of being able to export all or selected exif data out to a CSV file.
I'll keep messing around and report back if I find a solution. I'm thinking that I should be able to do this with photoshop.
Cheers! -
Ulead's DVD MovieFactory 6 Plus will let you create a slideshow. It will also let you generate a subtitle using the filename and/or EXIF data (the subtitle will be switchable to on/off using the DVD Player's subtitle button -- or dvd software show/hide subtitles -- in other words, you do not get a MENU that turns them on/off).
Regards,
George -
Do you know that the latest version of the free DVD slideshow GUI lets you import and overlay exif data onto jpg's and output them in many formats including a ready to burn dvd?
You might even be able to import a avs file from DVD slideshow GUI into Vegas(but I don't know I don't have Vegas)
How to combine video data and audio data in realtime
By mudassar in forum Video Streaming DownloadingReplies: 0Last Post: 31st Aug 2010, 09:00 -
EXIF capable slideshow editor
By aod in forum Newbie / General discussionsReplies: 9Last Post: 29th Oct 2009, 14:23 -
overlaying an image to a video
By videolearner1234 in forum EditingReplies: 3Last Post: 13th Jan 2009, 13:18 -
Overlaying/generating beeps & pauses during video
By jmelvin in forum EditingReplies: 5Last Post: 27th Feb 2008, 01:29 -
Vdub overlaying video track
By SearchQuality in forum EditingReplies: 0Last Post: 1st Dec 2007, 10:01
