I am using TMPGEnc Xpress to encode some video files into mpeg and when I add videos in the source tab, the little ffdshow audio decoder icon appears on the bottom in the system tray several times depending on the number of files I have added. I usually try to add only 10 but only 4-6 of them will show up and the rest will receive several errors, including access violation/access denied/audio part cannot be played. I usually just go and try adding the ones that didn't go through again and they will eventually work.
However, once I start encoding, it is a hit or miss whether these access violation/access denied/memory something error will appear during encoding and I don't want to have to go click on it and re-setup the encode for the un-encoded files every time there is a violation or error. I can sometimes encode all the files withouet errors and someetimes the error pops up.
I think it has something to do with the ffdshow audio decoder based on the many systray icons and the "audio part cannot be played" error that sometimes appears. Is there a way to fix this in ffdshow or do I have to use a different decoder?
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
An out-of-bounds memory access (access violation)
By rjc7394 in forum Video ConversionReplies: 0Last Post: 17th Jun 2010, 17:42 -
Virtualdub....An out-of-bounds memory access (access violation) occurred...
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 8th May 2010, 00:40 -
Virtualdub - out-of-bounds memory access (access violation) Lameacm
By kidcash in forum Video ConversionReplies: 1Last Post: 21st Jan 2008, 08:34 -
DVDAuthorGUI - Status Access Violation
By ecc in forum Authoring (DVD)Replies: 13Last Post: 12th Dec 2007, 00:47
