Hello,
Some raw data first:
- HTPC based on Vista Ultimate
- Audio output only through S/PDIF
- Connected to a 7.1 audio system
- I have no problems with video codecs
- I am mainly using PowerDVD Ultra or GOM player
- I only playback HD files, no encoding
- I only playback files widely available on the net. MKV, WMV, AVI, TS, BlueRay, HD-DVD, etc..
My problem is only with audio playback. Most files play OK except:
- WMV files encoded with multichannel audio (codecs WMA3, WMA9)
- mkv encoded with DTS soundtrack are clipping or stuttering
Please help, I have tried everything available. It's the understanding and the method I lack most.
Do ALL files in those formats have problems or just some of them?
Reason I ask is that Internet files are a total crapshoot. Quite possible they were just improperly encoded.
Can you obtain some sample files from a known good source and test those? -
I run everything in XviD with MP3, MP2, or the native AC3 encoding. For the passthrough of AC3 I just use AC3Filter that comes with the klite codec pack.
Definitly try to tinker with some different codec configs. It took me a while to get klite installed just right to play all my files and formats correctly.
I use AC3Filter for DTS decoding as well, though my receiver shows it playing as Dolby Digital.Ansuer - "try not... do... or do not... there is no try" -
Another one ... klite codec pack ... leave it out .
Install only codecs you actually need and have less issues later .
But there are numerous issues here , both from pc setup and format .
It may be a simpler task to unpack those problematic files , and repack into a format known to work on the current system .
I like Nelson37's usage of the term "crapshoot" in relation to internet accessed content ... You never know if it will play correctly , until its completely downloaded ... which could be a waste of time and effort .
Expert Recommendations!
By Huha in forum Newbie / General discussionsReplies: 2Last Post: 11th Sep 2011, 02:50 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 15:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 15:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 20:52 -
Is this possible? MPC expert please
By ferry1 in forum Software PlayingReplies: 3Last Post: 8th Jun 2007, 19:09
