    Feb 2007
    i got some verbatim dvd +r dl
    i burned an iso of a movie with dvd drcrypter, it burned fine, and verified, i opened a video player on the computer and it played.
    took it out of the computer and tried it on 3 different home players to no avail
    put it back in the computer, and it shows nothing, under my computer and doesnt play or anything
    any ideas, i dont want to keep making coasters with these things, there not cheap enough yet
    Feb 2004
    Pleasant Hill, CA
    A general suggestion would be to use ImgBurn to burn your DVDs - it's the updated burning-engine portion of DVD Decrypter. It should perform better as a burning app.
    Jim
    Oct 2006
    Canada
    What format was your ISO file?
    Was it DVD (Mpeg2) or DivX (Mpeg4)?
    If it is right file ImgBurn should do the trick.
    Feb 2007
    will imgburn decrypt discs as dvd decryter does,
    should i replace decrypter with imgburn, or have both
    Feb 2004
    Pleasant Hill, CA
    No, although ImgBurn will read NON-encrypted DVDs.
    I'd say both, although development has ceased on DVD Decrypter . If you wish to decrypt more recent DVDs, you'll need something like DVD Fab HD Decrypter or RipIt4Me (may take some effort to locate).
    Jim
    Feb 2007
    i have ripitforme, which uses decrypter, so i should probably keep it
    can you tell me what this "auto" means in pic 1
    and also how do i set up this layer break, and can it do it for me, i have no experience in DL media, but i have some i want to use
    thanks
    Feb 2004
    Pleasant Hill, CA
    IIRC, the "Auto" auto-calculates the project size to show the min size of media for the project (in your case DL DVD).
    I've not done a ton of DL media either, but pick either of the "Good" layer breaks.
    There's several guides & FAQs over at the ImgBurn forums:
    http://forum.imgburn.com/index.php?
    Jim
    Feb 2007
    hey guys img burn did the trick, works great
    thanks
