Hi there,
I am trying to make a DVD with this single file named: Black Snake Moan.avi but when I try and create the DVD this is the message when the error box pops up.
Any help is appreciated.
THX
Curtis M.
Version: SVCD2DVD 2.5
Build: 2.5.2728.36230
Type: System.IO.FileNotFoundException
Source: mscorlib
Message: Could not find file 'C:\Recorded TV\Black Snake Moan\Black Snake Moan_S2D.mpg'.
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileInfo.get_Length()
at x3284ccece41ee22b.xd3764d4f1e921081.x2e6504f39decc 498()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Results 1 to 12 of 12
I did that and now this error appears:
Build: 2.5.2850.0
Type: System.AccessViolationException
Source: SVCD2DVD
Message: Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
InnerException:
StackTrace: at x3284ccece41ee22b.xd3764d4f1e921081.AuthorDVD(xc76 139390a97debb xd2637df501625a82, x81974c36d7fdf1e1 xb4ee5c1758e9e983, Int32 xdc4f66b5011a3c9d, String[] x738d70b20493db82, Boolean x6b20cb17e8070d92, Boolean x3c21da9f928aac10)
at System.Threading.ThreadHelper.ThreadStart() -
CAn you post your log file please for this run?
I'm sorry but I can not find the log anywhere as before it would be in the logs folder in the main directory but this is not the case right now.
Help->"Open Logs Folder" from the menu.
Here you go:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.2850.0
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2.57 MB
Executable size in bytes: 2699347
Executable CreationTime: 7/6/2007 9:44:12 PM
Executable LastWriteTime: 7/9/2007 4:07:18 AM
Executable LastAccessTime: 7/9/2007 8:09:53 PM
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1033
CodeSet: 1252
CountryCode: 1
Local: 0409
Total Physical Memory: 0.99 GB
Free Physical Memory: 127 MB
Total Virtual Memory: 1.99 GB
Free Virtual Memory: 1.96 GB
***************************** Computer *****************************
Computer Manufacturer Name: ASUSTeK Computer INC.
Computer Model: A7N8X2.0
System Type: X86-based PC
Computer Name: ATHLON
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: ATHLON\Curtis
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 2600+
Description: x86 Family 6 Model 8 Stepping 1
CPU Speed: 2.079GHz
CPU FSB: 166MHz
L2 Cache Size: 256 bytes
***************************** Time Zone ****************************
Time Zone: (GMT-08:00) Pacific Time (US & Canada)
****************************** VIDEO *******************************
Name: NVIDIA GeForce 6200 A-LE
Processor: GeForce 6200 A-LE
Mode: 1280 x 1024 x 4294967296 colors
Video Ram: 256 MB
Status: OK
Name: LogMeIn Mirror Driver
Processor:
Mode:
Video Ram: 0
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 47.0 GB
DeviceID: F:
FileSystem: NTFS
FreeSpace: 1.94 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<SVCD2DVD DateTime="7/9/2007 1:09:58 PM" Filename="NONE"><AssetSet><Asset ID="1f78195b-c24b-46d1-a29f-9264a8347457" Path="C:\Recorded TV\Black Snake Moan" Filename="Black Snake Moan.avi" /></AssetSet><DVDStructure><TitleSet Name="New Movie" PostCmd="" MenuButtonType="0"><MenuButton X1="0" Y1="0" X2="262" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">Menu Button</MenuButton><Title Name="Black Snake Moan.avi" AssetID="1f78195b-c24b-46d1-a29f-9264a8347457" MplexOffset="0" /></TitleSet><DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" /></DVDStructure><Settings><General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="False" UseDVDShrink="True" /><Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" /><Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="True" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" /><Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" /><Burning BurningMethod="ImgBurn 2+" ImgBurnPath="C:\Program Files\ImgBurn\ImgBurn.exe" DVDDErase="True" DVDDClose="True" DVDDDontBurn="False" /></Settings></SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 901 MB
file=C:\\Recorded TV\\Black Snake Moan\\Black Snake Moan.avi
FormatName=avi
Num_Frames=160671
DurationInSecs=6701
Duration=01:51:41.3
VideoCodec=mpeg4
VideoFFSTNum=0
Width=624
Height=352
Standard=NTSC (Film)
BitRate=1128
AudioStreamCount=2
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=mp3
Audio1BitRate=96
Audio1Channels=2
Audio2FFSTNum=2
Audio2StreamID=[0x2]
Audio2SampleRate=48000
Audio2Codec=mp3
Audio2BitRate=96
Audio2Channels=2
AVI2MPG: 4968kbs Full-D1
13:09:58: Looking for AVI PAR...
Pass 1/1: Processing Black Snake Moan.avi
13:10:00: AVI2MPG: done.
13:10:00: Done: Processing assets for DVD creation
Authoring DVD Folders
13:10:00: Creating TitleSet # 1
13:10:00: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
13:10:00: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
13:10:00: libavutil version: 49.1.0
13:10:00: libavcodec version: 51.27.0
13:10:00: libavformat version: 51.12.1
13:10:00: built on Jul 6 2007 10:07:53, gcc: 4.3.0 20061204 (experimental)
13:10:00: Input #0, avi, from 'C:\Recorded TV\Black Snake Moan\Black Snake Moan.avi':
13:10:00: Duration: 01:51:41.3, start: 0.000000, bitrate: 1128 kb/s
13:10:00: Stream #0.0: Video: mpeg4, yuv420p, 624x352, 23.98 fps(r)
13:10:00: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 96 kb/s
13:10:00: Stream #0.2: Audio: mp3, 48000 Hz, stereo, 96 kb/s
13:10:00: Output #0, dvd, to 'C:\Recorded TV\Black Snake Moan\Black Snake Moan_S2D.mpg':
13:10:00: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 4968 kb/s, 23.98 fps(c)
13:10:00: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
13:10:00: Stream #0.2: Audio: mp2, 48000 Hz, stereo, 448 kb/s
13:10:00: Stream mapping:
13:10:00: Stream #0.0 -> #0.0
13:10:00: Stream #0.1 -> #0.1
13:10:00: Stream #0.2 -> #0.2
13:10:00: [mp2 @ 00822700]bitrate 448 is not allowed in mp2
13:10:00: Error while opening codec for output stream #0.2 - maybe incorrect parameters such as bit_rate, rate, width or height
13:10:00: Using pulldown.
13:10:00: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
13:10:00: -->: DVDFolders creating VTS
13:10:00: -->: VTS 01
13:10:00:
DVD Folders: Processing C:\Recorded TV\Black Snake Moan\Black Snake Moan_S2D.mpg...
13:10:00: -
Ok - if you redownload this should be resolved.
ChrissyBoy,
Sorry I'm not sure what you're referring to redownload?
THX -
Um...redownload SVCD2DVD...Originally Posted by CurtisMinBCDwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Did you update the file without changing the description again? It still shows version 2.5.2850 as the latest download and that's what CurtisMinBC is already using.Originally Posted by ChrissyBoy
Everyone,
I uninstalled then reinstalled again and now it is working fine.
Thanks again for such world class support.
Curtis
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 09:58 -
dvd burning error when make a bootable dvd image
By junian116 in forum Authoring (DVD)Replies: 1Last Post: 5th Apr 2011, 04:58 -
DVD Shrink Error: Programing Error, exception occurred
By lapetite_66 in forum DVD RippingReplies: 5Last Post: 2nd Jun 2010, 16:59 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41
