Page 2 of 2
FirstFirst 1 2
Results 31 to 42 of 42
  1. I'm a MEGA Super Moderator Baldrick's Avatar
    Convertxtodvd makes a dvd with switchable subtitles so you must turn it on manually with your remote control.
    See http://forums.vso-software.fr/how-to-activate-subtitles-on-tv-and-pc-t14366.html
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Are you playing DVD after ConvertXtoDVD has produced a normal DVD ie VIDEO_TS folder derived from your MKV file with embedded subs?
    Check the DVD on your computer with VLC and turn on the subs if necessary - can you see them? If VLC shows them then the problem is with your DVD player. Maybe you need to turn them on via your DVD remote?
    Or are you playing a MKV file copied to a data disk and the DVD player is not playing the subs? Once again this is the DVD player problem.
    Are you sure ConvertXtoDVD picked up the subs - it will say so in the log and on the main screen ie subs (1)
  3. FYI, I have tried in 2 different DVD Players and I have turn it on via remote control. ( Still same).
    And also it's not showing on VLC media player. Let me figure it out.
    Give me some time. I will try and let you know the result.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    The majority of DVD players have the subs default off - in the setup menu of most DVD players you can turn them on as default. If none of your players can do this all you have to do is to remember to turn them on using your remote. Same with VLC you need to go to the menu item
    Video and then scroll down to the second item Subtitles. If there are subs on the file it will have a menu that says Open file, Disable, English 1 etc etc
    Do you want to permanently burn in the subs so that they are part of the image?
  5. Well, I will try in this week and will let you know the outcome.
    Anyway, thank you very much guys for your quick response.
  6. Please view the image
    You can view it from the attached screenshot there is a subs(.srt)
    After Conversion it's doesn't show me the subs even in VLC or DVD Player.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Are you turning on Subs in VLC?
    Are you turning on subs on your DVD player?
    ConvertToDVD will not "burn them in" so that they form part of the image - you have to turn them on in the player whether it is a standalone DVD player or a software player like VLC.
  8. It's on my friend in VLC and DVD Player.
  9. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Well the image you posted indicates they are there - could you post a mediainfo report using VTS_01_02 from the DVD files you made using ConvertXtoDVD - I have deliberately selected the second file in the collection to make sure the subs are there. The report using text mode (copy and paste into post) should look like this. My original file didn't contain subs and had to do a search and I found a SRT.
    If there are subs on your authored DVD then the word TEXT and details should show up at the bottom like this example.
    General
    Complete name : C:\Users\Netmask\Documents\ConvertXToDVD\El Secreto de sus Ojos (2009)\VIDEO_TS\VTS_01_2.VOB
    Format : MPEG-PS
    File size : 1 024 MiB
    Duration : 53mn 35s
    Overall bit rate : 2 672 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=13
    Duration : 53mn 34s
    Bit rate mode : Variable
    Bit rate : 2 426 Kbps
    Maximum bit rate : 9 016 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.234
    Stream size : 930 MiB (91%)
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Muxing mode : DVD-Video
    Duration : 53mn 35s
    Bit rate mode : Constant
    Bit rate : 192 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Delay relative to video : -568ms
    Stream size : 73.6 MiB (7%)
    Text
    ID : 189 (0xBD)-32 (0x20)
    Format : RLE
    Format/Info : Run-length encoding
    Delay relative to video : 2s 20ms
    Menu
  10. Yeah...It's working in sudden....
    Thank you very much to all who help me..
    Cheers.. Mathan
  11. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    aaaargghh! I'm sure we would all love to know why?
  12. Just you have to put in the MKV and srt file in same folder and literally have to wait 1 or 2 second for sub to display in VLC media player.
    Manually choose in VLC media player ...Video > Subtitles Track > Track 1
