Sorry, I think I might of posted this on the wrong forum. I apologize.
Hello everyone. Newb in the house.
this forum is pretty cool. I just started doing some converting files to dvds.
I am using convertxtodvd
well, here is my problem.
I downloaded Samurai 7 (DVD ripped)
The subtitles are embedded in the files.
THey play perfect on my PC.
So when I finished converting and burning to dvd, and I try to play on my tv. the subtitles dont show. the quality is great but no subtitles.
I think I read something about overscanning, but still havn't grasp it.
Thanks for all your help.
Results 1 to 30 of 42
Oh yea, when I choose the Preview option on convertxtodvd screen, I see no subtitles. compare to dvdshrink when its encoding you can see the subtitles while previewing it.
hopefully that makes sense.
thanks. -
Do they show when you play the DVD on your computer? Overscan is just a TV phenomena. The whole screen should show on a computer monitor.
And welcome to our forums.
I forgot to mention that.
The subtitles do not show when i play the dvd on my PC.
Thanks. -
Use the Subtitle button on your remote to turn them on. There is a check box in the settings for ConvertXtoDVD to make subs on by default (I think - could be wrong) but your subtitle button should trun them of if they are there.
Read my blog here.
Originally Posted by guns1inger
I checked and the subtiltles default button is automatically turned on. I tried on the TV but no results.
The files are mkv. I dont know if that has anything to do with it. Plus, I was working on microsoft word while the converting process (does this affect the process?).
thanks -
Word should have no effect. I don't believe ConvertXtoDVD will take subtitles from within an MKV contanier - you would have to give it external subs - .srt format is the most universally accepted.
Read my blog here.
There are too many sites.Originally Posted by gtorres001
Best international are:
http://titles.box.sk/
http://www.opensubtitles.org/en
http://subtitles.images.o2.cz/
and there is a search engine:
http://www.subbiee.com -
Originally Posted by Jeremiah58
I'll try these websites when I get home.
I'll let you guys know what happens.
thanks. -
okay, so this is what I am trying at this very moment.
I used dvdshrink to encode and then use convertxtodvd to convert and burn.
I can see the subtitles in the preview box( convertxtodvd ). so I hope this works. I'll post results in a hour.
:crossingfingers:
gtorres001 -
U will need to extract the subs before converting using MKVExtract. Then just rename the subs to the same name as the movie if u want CXTDVD to pick them up auto or u can select the subs manually thru the list.
Matroska Media File ( A.k.a mkv)Originally Posted by romi7519
gtorres001 -
So when I am extracting MKVExtract I get the following message:
"mkvextract.exe and/or mkvmerge.exe file not found in the same MKVextractgui folder. copy them into this folder and try again."
But MKVextract still opens after that dialog box. So in the MKVextractGUI main i try to drag the files and i get the following error:
"Error creatin Chilg Process
CreateChildProcess (ExeName, commadLine, FChildStdoutwr)"
Hopefully that makes sense.
Oh yea, my dvdshrink to convertoxdvd worked, but when i played it on my tv, the subs were cut off. Should I resize to Full screen 4:9 ratio.
thanks -
MKVExtractGUI requires that mkvtoolnix be installed to the same folder (the folder in which MKVExtractGUI is installed).
If cameras add ten pounds, why would people want to eat them? -
So once i do this i wont get the following error message:Originally Posted by Ai Haibara
thanks -
once i copied the mkvtoolnix into the mkvextrackgui folder.
i wish i could show you guys.
I still get the same message
thanks -
am i suppose to copy the files from cd to my hardrive.?
b/c mkvtoolnix is taking a long time to demux them. well, the program freezes.
thanks -
gtorres001: What did you download in regard to mkvtoolnix? It should be an installer file that contains the files MKVExtractGUI is looking for. If you're following the Download link from VideoHelp's mkvtoolnix page, look for the Windows installers at the bottom of the homepage (the version you're looking for should be the following: "Unicode enabled (Windows NT, 2000, XP or newer) installer v2.0.2-1"). Or just click on the Mirror link on VideoHelp's mkvtoolnix page, and it'll download the same installer.
Yes, it should solve those 'child window' problems as well.
Run the installer and tell it to install to the directory in which you have MKVExtractGUI installed.
I should note that the demuxing isn't necessarily a quick process, but it shouldn't take that long.
The videos you're attempting to demux? I don't think it's absolutely necessary, but it'd probably be a good idea.am i suppose to copy the files from cd to my hardrive.?If cameras add ten pounds, why would people want to eat them? -
Hello, I'm also a new member. MKV's have been giving me a lot of trouble lately,despite all my research. I'm doing exactly as you say, and yet I'm still getting the Child Process error. Also, I have the same problem so I want to use the extractor over the merger, correct? The merger also seems to separate the files, but it isolates the subs as mks, which convertx can't read as a subtitle channel. Am I making this more complicated than it is?
I will, thank you should I let it download that Haali splitter? If I do, should I let it disable the internal and Gabest's mkv splitters, as well as check the box to associate mkv and mka with windows media player? The program doesn't seem to touch on mkvs at all. Thank you for trying to help, I appreciate it!
I tried to burn it but it can't process the subtitles. When I put in the file it asks for a file to extract the subs from so I put the same file in there and it lets me check the subs but then there is no okay button. All I can do is just exit that. I did so and let it burn but then it came up with several messages saying there was an error reading the subs. Any ideas to fix it?
Why not simply demux the original to extract the subs as separate IDX and SUB files or SRT whatever they are, then put them in the same folder with the video and ConvertXtoDVD should pick them up.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Can I know what is the resolution for this problem. How do I add subtitles using ConvertX to DVD for MKV files
If the MKV file has subs contained then ConvertXtoDVD will pick them up. If the MKV doesn't have subs then open the MKV file in ConvertXtoDVD and where it says subtitles none right click on that entry and you will have an option to ADD a subtitle. Of course all of this is in the help file that these days no one seems to bother to read. Yes I'm grumpy because I've spent the afternoon showing people the bl***y obvious!!! Please remember the right mouse button it can do wonderous things sometimes
MKV file pick up the subs but when I play the movie in DVD player it's not showing up the subtitle.
Please advise
ConvertXtoDVD subtitle issue.
By Randwill in forum SubtitleReplies: 3Last Post: 7th Sep 2011, 10:01 -
ConvertxtoDVD - Subtitle #2 (subtitle) etc Coodec Tag "mp4s" Unsupported
By Simmons in forum Video ConversionReplies: 0Last Post: 10th Jun 2011, 06:36 -
ConvertXToDVD Subtitle encoded file?
By theamilien in forum SubtitleReplies: 0Last Post: 16th Aug 2010, 04:07 -
No Subtitle w/ ConvertXtoDVD
By NautTboy in forum SubtitleReplies: 2Last Post: 28th Feb 2008, 09:07 -
ConvertxtoDVD subtitle settings, how to get less space between sentences?
By DavidHazelnut in forum Authoring (DVD)Replies: 6Last Post: 18th Nov 2007, 21:10
