Hi everyone!
Maybe this has been actually answered but can't find anything...
Well, I have some Avi files (x264 + MP3) which I want to mux to MP4 so they can be played in a Xbox 360 (don't know if x264 will play but I'm trying so I can find out the answer).
I don't really know if there's specific steps to extract the x264 stream from the avifile, but extracted with VDub, extracted audio as Wav and used BeLight to turn it into AAC...
With this done, I've tried using YAMB, but some problem appears while trying to mux
Error importing [file].h264: BitStream Not Compliant
What does it mean???
can I still doing this conversion or is better to leave them as they are????
mp4box can only handle avi input for MPEG-4 Part 2 (Xvid, DivX, etc.). VDub only saves avi's so you have an avi with a .h264 extension. You need to use something like avi2raw to get an actual raw stream.
The 360 as I understand it will play it as long as the stream is HP 4.1 or lower. Also I hope you saved the audio as LC aac, not HE. -
Thanks, forgotten to reply...
well seems the audio was encoded correctly but video appears to be non compliant, I don't really know why, I'm gonna try again
MkvToMp4 vs YAMB
By jandor2009 in forum Video ConversionReplies: 0Last Post: 4th Jan 2012, 05:52 -
Can MP4Box does everything YAMB could?
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2011, 11:07 -
Can Someone recommend an Alternative to YAMB
By Scarpad in forum Blu-ray RippingReplies: 4Last Post: 5th May 2010, 14:39 -
Yamb Source Code
By simonrule in forum ProgrammingReplies: 0Last Post: 3rd Nov 2009, 11:50 -
mkv, mkv2vob,yamb and the PS3
By sulimo in forum Video ConversionReplies: 1Last Post: 31st Oct 2008, 03:22
