I need to know firstly
Can i burn VCDs that are a file size larger than 650 meg - i.e 660 onto a 700 meg CD - will this work in my VCD player
Second
It is currently in a resolution of 720x336 - will it work in a standard VCD player - or will i need to re-encode at a lower or compatible resolution
If so please could someone tell me what are the compatible resolutions for VCD.
Thanks for ya help
Chris
yes to both questions.
yes you are fine with the 660 on a 700mb though you can fit the 660mpg on a 650 disc if you are using nero
yes you'll have to re-encode the disc to meet vcd standards to find the resolution click the link on the left that says vcd.
actually most of your questions can be answered by checking out the various links on the left.
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 10:47 -
Looking for an MPEG-2 Encoder like CCE and FFMPeg Questions
By Maikeru-sama in forum Video ConversionReplies: 85Last Post: 31st Aug 2008, 23:24 -
Convert MKV to MPEG-2...format questions, etc.
By pcombs in forum Video ConversionReplies: 1Last Post: 20th Jul 2008, 16:58 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
converting avi to mpeg-1 help plz??
By darealest1 in forum MacReplies: 5Last Post: 12th Jul 2007, 21:43
