Hey guys. Gotta question about audio in an XVID/AC3 tv episode. The music and environmental noises drown out the voices. At some points I can barley hear the voices, but the music and the othe rnoises are way louder. Someone suggested messing with the compression in Audacity. Is there a way to make the voices louder, or lower the volume of everything else bu the voices? Would compression change it? Any help would be greatly appreciated!! Anyone have some suggestions?
try Besweet it can divided Batches.....
Do other AC3 sources play correctly to 5.1? In other words are you confident your monitoring is properly set up and you can hear all 6 channels?
What you describe is typical of listening to L and R channels without a center channel.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thank you for the responses yall. I downloaded a whole bunch of filters and plugins having to do with AC3 and the audio is fixed. I appreciate the help very much!
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 08:21 -
Remove Voices And Background Music From A Video
By DigitalDummy24 in forum AudioReplies: 5Last Post: 6th Mar 2010, 01:07 -
AutoGK Preview (High Pitch Voices)
By Blue_3 in forum AudioReplies: 0Last Post: 28th Mar 2008, 20:27 -
I have an AVI voices are in left headphone, music in the right side
By vectoravtech in forum AudioReplies: 14Last Post: 13th Feb 2008, 11:51 -
High Voices and Audio Sync Problems
By canada8668 in forum Newbie / General discussionsReplies: 2Last Post: 25th Jul 2007, 17:51
