I created a DVD from a VHS home video source but my DVD player(s) are having trouble keeping up with de-interlacing the material when displaying on a flatscreen. I get hot spots of areas that arent deinterlaced. I was hoping to send out a few copies but can't if it'll look this aweful for people with newer lcd displays.
PowerDVD in Windows studders and jitters trying to deinterlace unless I set it to Bob.
WinDVD seems to manage fine.
Faroudja based player has major hot spots
$20 walmart player - very bad
I captured my old VHS tapes in 720x480 lossless avi, edited full res, exported uncompressed and then encoded in CCE VBR 6mbps average. Am I missing a step? Should I be deinterlacing and then somehow re-interlace with less complicated information?
Sounds like you need a better DVD player. What do you expect for $20? Try a different one. It's also possible you reversed the field order. Did you keep the file interlaced all the way through your editing and encoding process? You should never deinterlace or reinterlace stuff.
One of his players is a $20 player. But he also has a Faroudja chipset player, which has about the best deinterlacer in the game. If interlacing gets through it, I suspect something went wrong somewhere along the line.
Removing jagged interlacing artifacts from a progressive file?
By tfolder in forum RestorationReplies: 13Last Post: 17th Mar 2011, 04:19 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 21:23 -
Interlacing artifacts appear from interlaced clips?? Sony vegas + tmpg
By mazinz in forum EditingReplies: 10Last Post: 28th Sep 2008, 19:51 -
Interlacing artifacts on poor VHS conversion
By binister in forum Video ConversionReplies: 6Last Post: 2nd Jul 2008, 19:05 -
Is there a way to fix this?(maybe interlacing artifacts)
By Lure in forum RestorationReplies: 10Last Post: 5th Jan 2008, 11:37
