I have a Sanyo camera that saves in MP4 format. I need a program that can edit the files. I just need basic cut and paste, not any special effects. I have tried a couple (TMPGenc with quicktime addon and MPEG Streamclip) and the results are in black and white for some reason. Any suggestions, preferablely freeware. thanks
Hi,
Check out http://mp4cam2avi.sourceforge.net/ This app will convert your Cam Vids to AVI format which is a better editing format and will allow you to use VirtualDub or AviDemux for simple editing etc.My Site: http://www.bandshed.net/AVLinux.html
My Guide: https://forum.videohelp.com/topic330839.html -
this is just a p.s. I figured out the B&W problem.... I'll check out the AVI converter, would still like a simple cut & paste without re-encoding program
Hi
Just for the record MP4Cam2AVI doesn't re-encode the video either it trancodes the Audio to .mp3 a leaves the video alone and puts it in an AVI Container, MPEG Streamclip is also a good prog, it's a little clunky for editing though. AviDemux also may be able to take your clips as-is.My Site: http://www.bandshed.net/AVLinux.html
Sanyo Xacti FH1 & .MP4 1080p woes
By lucky644 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 7th Jun 2013, 10:19 -
a program to edit mp4 videos from a digital camera
By alc112 in forum EditingReplies: 3Last Post: 17th Jun 2011, 03:10 -
Software to edit MP4 (H.264) files from my camera
By Gionames in forum EditingReplies: 3Last Post: 13th Dec 2010, 23:20 -
Help with Corrupt mp4 video files. from Sanyo WH-1
By Jmiller0921 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 31st Mar 2010, 22:27 -
Sanyo HD1000 MP4 File joining - codec problems
By 737 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 1st Apr 2008, 13:26
