Ok, here's the situation:
I have a movie file in AVI format with a subtitle file in SRT format and the subtitles work 100% perfectly, but unfortunately they are in foreign language.
Then I have another subtitle file also in SRT format that's in correct language but it's totally out of sync and in different framerate and with all sorts of problems. I tried syncing it with Subtitle Workshop, but after 5 hours of syncing I gave up. Either the middle of the movie is out of sync or the end or both.
But both the subtitle files have exactly 447 lines of text. So would it be possible to somehow automatically take the timings from the first subtitle for each line and place these timings into the second subtitle file? I tried to find this option in Subtitle Workshop and in TimeAdjuster, but just couldn't find it.
Is there some way to do it automatically (instead of manually copying and pasting every single line with notepad which is a very frustrating process)?
Sounds extremely simple in theory, but I just can't find the correct option.
/Edit: Ok, I already found it.
In Subtitle Workshop:
Menu -> Edit -> Timings -> Read Timings from File
Results 1 to 1 of 1
Replace subtitle timings
By Abas-Avara in forum SubtitleReplies: 3Last Post: 19th Jun 2010, 08:32 -
Overlapping subtitle timings for multiple entries onscreen?
By viewpoint in forum SubtitleReplies: 1Last Post: 30th Aug 2009, 21:22 -
SubtitleCreator - How to put in a delay for parts of the subtitle
By gustav32 in forum SubtitleReplies: 3Last Post: 19th Jun 2009, 13:51 -
How to change the subtitle position?How to put it on the top of the screen?
By user2008 in forum Newbie / General discussionsReplies: 3Last Post: 12th Feb 2009, 07:07 -
Can anyone help me how to put a subtitle that can play in any dvd players!
By 8okkin21 in forum SubtitleReplies: 4Last Post: 16th Jan 2008, 08:15
