Hello...
i am trying to convert some hi8 tape footage to digital...I am using a hi-8 camera passing through into a mini-dv camera (using the svhs plug) and then into my macbook imovie program (using firewire). on both the hi8 and mini-dv camcorders, the image looks fine...and when i hook both camcorders up to a tv, the image looks fine...but when i capture it onto my computer, there is a small line of distortion on the very bottom and very right hand side of the image. it does not do these things when viewing on camcorders or on the tv. is this a regular occurrence? im wondering what can be done about this? is there any software that would help? unfortunetly, i dont have a standalone tbc...any advice would be appreciated!
thanks in advance!
~adam
ps- my jvc 7600 VCR does have a tbc function...could this somehow be used in somekind of convoluted way?
	That's normal for any analog material, if you view on TV and compare to your computer you'll notice some of the video is cut off on the TV. That's the overscan area. You'll only see this on computer because it displays the whole frame. If you want to get rid of it you can mask it with black.
 Suggest you request a mod to move your thread to the Mac forum because they rarely venture out of there. :P
  Hi8 to miniDV questionBy low613 in forum Newbie / General discussionsReplies: 6Last Post: 20th Jan 2010, 13:32
  Sony Hi8 has been defective but want to play the Hi8 tapeBy coody in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 22nd May 2009, 23:06
  Hi8 encodingBy devin122 in forum Video ConversionReplies: 17Last Post: 17th Jan 2008, 12:41
  Hi8 vcr, better playback than a Hi8 camcorder?By Knightmessenger in forum Capturing and VCRReplies: 8Last Post: 22nd Dec 2007, 02:11
  Will cheap new Hi8 camcorder output better than old, worn Hi8 camcorder?By ErikL7 in forum RestorationReplies: 7Last Post: 2nd Sep 2007, 07:26
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
