Hi, everybody,
I have few mpeg1 ( 352x288) clips and I need to convert this to mpeg2 file to
Author dvd.if I re-encode this files in higher bit rate (8000 kbps) the picture quality will improve or it will be the same ?
Results 1 to 10 of 10
No, any conversion will lose quality.
But you can use MPEG1 video on a DVD. You just have to convert the audio from 44 to 48 k sampling rate.
You can use the free version of SVCD2DVDMPG to do this, you'll get your MPEG1 video and an MP2 audio file that you can use in a standard DVD authoring program.
Also, you can use TMPGEnc to cut or join MPEG1. -
Thanks all of you.
but I have seen in some forum that 352x480 or 352x756 will be more quality
while converting from 352x240 or 352 x 288..can any one clarify?
if so, we have to choose CBR or VBR ?
[/img] -
Is there some specific problem with the original video? Scratches, dust spots, etc?Originally Posted by live4fun
Cartoons with lots of jaggies?
If you're trying to fix some flaws in the image, you'll have to filter it and thus reencode. Otherwise use the MPEG1 as-is. If it's a normal VCD-style video, you cannot make it better by upsampling. That kind of magic only works on CSI. -
I don't have any problem with my mpeg1 file. I was thinking of improving
video quality by encoding.
Thanks -
Then you got it all wrong. The very best (theoretically) you can hope for, is the same quality as the source after an encoding. In reality, you always lose some quality.Originally Posted by live4fun
/Mats -
MPEG-1 defines a framework for compressing video and audio, significantly reducing the amount of storage needed while keeping acceptable quality. The MPEG-1 video compression method takes advantage of the fact that often, many frames in a row are very similar (showing the same background and objects, for instance, with only an actor's face and hands moving). For each frame, it is only necessary to record how it differs from the previous frame, saving storage space. In addition, the audio encoding uses something called psychoacoustics—compression removes the high and low frequencies a normal human ear cannot hear.
MPEG-2 is not a successor to MPEG-1. Both of these formats have their applications. MPEG-1 is used in VCDs and on the web for short video and animation files. One of the MPEG-1 audio compression standards, MPEG 1 Layer III, is the most common compression method for audio files used on portable devices, under the name "MP3." MPEG-2 is used for higher resolution video, digital television and on DVD's. -
Originally Posted by live4funOriginally Posted by AlanHKOriginally Posted by guns1ingerDoes that answer your question?Originally Posted by mats.hogberg
Does Converting MPEG1 2 MPEG 2 improve quality?
By purpleronnie in forum RestorationReplies: 10Last Post: 7th Aug 2009, 16:47 -
What can I do to improve my quality?
By Captain Satellite in forum RestorationReplies: 12Last Post: 27th May 2009, 12:06 -
How to improve picture quality
By MI6 in forum Video ConversionReplies: 2Last Post: 25th Feb 2009, 17:37 -
VHS to DVD - is there any way I can improve quality of conversion?
By rairjordan in forum Capturing and VCRReplies: 21Last Post: 13th Feb 2009, 13:32 -
How to improve dark VHS picture?
By rbatty11 in forum RestorationReplies: 15Last Post: 11th Sep 2007, 19:57
