Hi all, please help me am having problem joining 2 AVI files. Here is the error message:
The audio streams do not share a common sampling rate..
First stream: 0000401a / 00000001 = 16410.00000 samples/sec
Second stream: 00004026 / 00000001 = 16422.00000 samples/sec
I hope anyone here can help me coz' I'm very much of a newbie and don't know how to correct this error. I used Virtualdub to join 2 AVI files and that's where I get the error message.
Note:
The dimensions, bit rate and frame rate are 640x272, 131Kbps and 25 respectively and the codec used is XVID. Got these infos from GSpot. I d/l the 2 AVI files from the net.
I have used the old program
NanDub (nandub v1.0 rc2) http://ndub.sourceforge.net/
with good success where VirtualDub has given me the same errors as you got.Hubba hubba zoot zoot.......... :) -
Hi redwudz thanks for replying unfortunately I have no idea in using AVIDemux
but it looks promising
. And to hubbabub I d/l the Nandub and it looks like Virtualdub so I tried it and open the first avi file and to my surprise there is no VBR warning message then append the second avi again there is no vbr error message and also the audio stream error but when I tried to play the avi file there is no audio is this normal? Do I have to save the 2 avi files first to be able to play, view and listen to it? And also I haven't altered anything yet I just open the first avi file then append the second. hubbabub can you please help me if there is anything else that I should do first. Thank you both for helping me. BTW there are 2 files for Nandub there is the binary and the sources which one should I use? Or should I use both? But how? I see the Nandub Binary which is where the exe file included but the Sources I don't know how, sorry coz' am really new in this.
Thanks a lot hubbabub! It works perfectly! I hope there's a manual for using Nandub do you know if there is one? BTW is it normal that when cutting a portion of the movie in Nandub I don't see a progress blue line unlike Virtualdub and the markings also?
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 13:52 -
joining avi files with diff frame rate-error in vd
By leel in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2010, 19:49 -
How to join AVI files with multiple audio streams
By V@no in forum Newbie / General discussionsReplies: 2Last Post: 29th May 2010, 23:17 -
joining serveral files with mp4box results in 2 video-streams
By Obc in forum EditingReplies: 4Last Post: 11th Jun 2009, 14:23 -
Audio out of sync (with over 0.5sec) when joining multiple avi files
By andy_blah in forum Video ConversionReplies: 28Last Post: 10th Aug 2008, 15:55
