Greetings,
I am curently trying to get a Dazzle DVC170 (AKA: Dazzle "Video Creator Platinum") to work on multiple systems.
On every system I have the same issue. The video signal shows up as solid black.
When I use the Pinnacle software, the video works fine, but I have no intention of using this capture device with their software. And all other applications only see the input source as black.
I've confirmed that the video signal is fine (both RCA and S-Vid) on multiple systems (AMCap, Capture Flux, Resolume, etc), so it all comes down to the DVC170...
I've spent the last 3 hours searching all over the interweb hoping to find some form of help, but every search has dead-ended.
Any help here would be greatly appreciated. I've even gone as far as to seach other hardware stores nearby to find other USB capture devices, but every store only seems to have devices manufactured by Pinnacle, and given that the DVC170 is only functioning properly when using their proprietary software, I'm shying away from them.
Thanks in advance for any help!
/Chris
Results 1 to 1 of 1
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 15:14 -
Time Domain Correction (TDC) and Black and White RS-170 video signal
By tpg in forum Capturing and VCRReplies: 0Last Post: 26th Nov 2010, 10:21 -
Black & White Capture w/ Dazzle!
By Rowan88 in forum Capturing and VCRReplies: 9Last Post: 12th Mar 2010, 14:42 -
Capture tv signal with mencoder
By mierdatuti in forum Capturing and VCRReplies: 1Last Post: 2nd Feb 2009, 02:39 -
Capture with Dazzle DVC170 with another program?
By Glaucous in forum Capturing and VCRReplies: 0Last Post: 19th Jul 2007, 09:53
